chevy 350 w/ mild cam.. idle/gear probs - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-21-2012, 03:01 PM
F-BIRD'88's Avatar
Yada Yada Yada
If it has a long duration cam you will never get it right untill you address the distributor advance curve. A low stall converter will not allow an engine to idle correctly in gear if the cam is big.
fix the distributor
Cam or converter swap, pick one.
  #17 (permalink)
Old 02-21-2012, 03:34 PM
F-BIRD'88's Avatar
Yada Yada Yada
The idle quality of the Weiand 7546 manifold is not that great in general.
Of al the different SBC intakes I have used this was by far the worst for idle quality, in general. Good power on a racey motor thou.
A really bad choice for a truck.
  #18 (permalink)
Old 09-26-2012, 05:46 AM
foodstamp's Avatar
poor boy's racing
small update after MIA
well i know its been a while since i last posted, ended up putting truck in the shop. carb issue never got fixed, but found out what cam was in it... it had a 292 comp cam... with 2 lobes completely wore off, 2 lobes thatrounded smoothly... so i had a howards cam and lifters installed. cam specs are
Strong Low & Mid-Range Torque
.447/.447 lift
280°/280° in/out
208°/208° in/out @050
111° lobe seperation
lifters came with the cam, says they are matched, but i think its more snake oil than anything...
a few more details about engine/trans: 3970010 block punched 30 over, the new cam/lifters,1.6 rollers,small camel hump heads and a 700r4 trans.
hope this helps
Rough idle, high idle in park, stalls in gear.. Help! ratmaro Engine 18 03-23-2012 05:29 PM
chevy 350 mild motor jeremy1992 Engine 15 01-03-2012 01:45 PM
mild built t-350 shudders in gear.. J0386 Transmission - Rearend 7 10-19-2011 01:12 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 11:49 AM
Anyone run a mild BB, 3:08 gear, 3000 stall? Frank K Transmission - Rearend 2 01-16-2004 08:42 PM
