Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - chevy 350 won't start
Old 03-22-2007, 05:38 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
One thing you might check, is the "Prime/Bypass" Circuit for the Fuel pump during crank mode..(refer to a Haynes manual to see if this has one)..
Also a loose or corroded fuel pump relay might cause the problem..
TO check the Prime circuit, you should be able to jump the oil pressure sender into thinking it has oil pressure, then try starting, If do it's in the prime circuit.
You may not be pulling enough fuel pressure while cold cranking to turn the fuel pump on..and actually start.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
