chevy 350ci engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2003, 03:17 PM
Post chevy 350ci engine
I KNOW THIS MAY SOUND DUMB BUT HERE IS MY PROBLEM.I BOUGHT 1930 MODEL A COUPE HOT ROD WITH A CHEVY 350 CI ENGINE IN IT. THIS CAR WAS BUILT IN 1960. THE NUMBERS ON THE ENGINE WHICH I TOOK OFF THE RIGHT FRONT ENGINE BLOCK ARE T1215CPB.HOW CAN I FIND OUT THE YEAR MAKE OF THIS ENGINE.
Old 02-06-2003, 03:59 PM
DoubleVision's Avatar
Post
I couldn`t find any suffix of CPB, but, there is a date casting on the back of the block on the bell housing, it will read something like A 5 0 which would be A= January 5 =5th 0 = 1970 or whatever year the casting number, which is also on the bell housing, was cast. T sands for Tonawanda engine plant, 12 = december 15 = 15th
Old 02-06-2003, 04:05 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
WOW, I didn't think there was a 350 made when the car was built (1960). <img src="confused.gif" border="0">
Old 02-06-2003, 04:20 PM
Post
WHY BOTHER WITH YOUR REPLY BSTMEC EVERY ONE KNOWS MODEL A FORDS ALSO DID NOT HAVE A 350CI ENGINE
Old 02-06-2003, 04:26 PM
Post
THANKS DOUBLE VISION YOUR INFORMATION WILL BE HELPFUL IN MY SEARCH.
Old 02-06-2003, 05:53 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
THE REASON I WAS POINTING THAT OUT IS IF YOUR CAR WAS BUILT IN 1960, YOU WOULD HAVE A 265 OR 283. I WAS CURIOUS IF THIS WASN'T A TYPING ERROR, AND I WAS GENUINELY CONFUSED WITH YOUR POST. SOOORRRRYYYY!
Old 02-07-2003, 03:23 PM
Post
HEY DOUBLE VISION GUESS WHAT? AFTER YOUR SUGGESTION I FOUND THE NUMBERS 355909 LOCATED ON REAR OF THE BLOCK AT THE DRIVERS SIDE. USING THE TECHNICAL DATA ITEM LISTED AT THIS SITE AND SEARCHING THROUGH TO CHEVY SMALL BLOCK ENGINE CASTING NUMBERS I FOUND THIS. IF I READ THE CHART RIGHT THIS ENGINE IS 1976 262CID. BOY WAS I SURPRISED I WAS TOLD BY THE SELLER IT WAS A 350 CID. THANKS CHECK ME OUT
Old 02-07-2003, 03:33 PM
5.0Towncar's Avatar
Post
I think Bstmech deserves an appology. Steve
Old 02-07-2003, 04:34 PM
Post
i just look at a v8 for $250 to a chevy <img src="graemlins/pimp.gif" border="0" alt="[pimp]" />
Old 02-07-2003, 04:38 PM
5.0Towncar's Avatar
Post
Yeah maybe he can e-mail you from coolsville as well. Steve
Old 02-07-2003, 05:46 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Wiretwister- I looked up the the number you got off your block (355909) in my numbers book, and it says you have a 76-79 305 cid. My book has had conflicting information with nastyz28.com's info once before, and my book was right. Even if it's a 305, it would still be a disappointment from having a 350, just not nearly as bad.
Are we feeling better today, or am I still a smart *****?
Old 02-07-2003, 09:14 PM
New Member
Post
he is right about not making a 350 in 1960 if you really need to know go to local race track[roundy roundy] and find engine inspector and have him run a volume test.you could also pull a valve cover and get a casting number off head. not real accurate but close also are the valve cover bolts staggered? that would make it a pre1960 motor last resort pull a head 4" bore is not a 260 or 305
Old 02-08-2003, 06:40 AM
Post
BsTmech THANKS FOR YOUR HELP AND I OWE YOU AN APOLGY FOR MY PREVIOUS COMMENT. I GUESS I WAS JUST VENTING MY ANGER ON YOU WHICH WAS CHILDISH,FOR HAVING SO MUCH TROUBLE DEALING WITH PARTS HOUSES.SEEMS YOU CANNOT BUY PARTS UNLESS YOU HAVE CAR MAKE,MODEL AND ENGINE SIZE. SORRY WIRETWISTER
Old 02-08-2003, 07:11 AM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
I hear ya'man, no problem. Good luck with your ride, and post some pics too! <img src="graemlins/drool.gif" border="0" alt="[drool]" />
Old 02-09-2003, 06:32 AM
Post
hey wiretwister have tried looking up <a href="http://www.mortec.com" target="_blank">www.mortec.com</a> , it's a really cool site and has lots of info on casting numbers and other info.
