Chevy 366 Big Block - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #16 (permalink)
Old 07-31-2009, 05:34 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yea i hear ya, And there ain't northing wrong with that You need to post some pics so we can see just what you have. Cole
Quick reply to this message
  #17 (permalink)
Old 09-05-2009, 12:18 PM
building a 366 bbc
great industrial motor to build loose the 4 ring truck pistons go to 4.250 bore strke 454 crank or 6.585 rods and have fun on bbc piston choice .I have one in my s10 blazer with an 871 huffer on top and dual preditors my daily driver on weekends when im home.
  #18 (permalink)
Old 09-05-2009, 12:26 PM
366 bbc
will try just got i phone will get on pics
  #19 (permalink)
Old 09-05-2009, 03:47 PM
my87Z's Avatar
Veteran/Firefighter-Paramedic
that's awsome i never heard of the 366, i know of the taller deck bbc blocks but never heard of the 366, always nice to learn somthing knew
  #20 (permalink)
Old 09-05-2009, 04:33 PM
302 Z28's Avatar
Friendly note, please turn off your caps lock when posting.
Vince
  #21 (permalink)
Old 09-07-2009, 02:34 AM
Last journal entry: finally got started
366?
hey I have two 366's and I love em' both.
  #22 (permalink)
Old 09-07-2009, 03:43 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by keith trammell
hey guys I have 2 camaros, a 68 with a 366 & a 79 w 388.
the 366 is .60 over steel crank old trw pistons comp roller cam 612/612
im running oval 148 heads, the heads have been ported & matched to torker intake a plate 200 shot of nos in a 68 camaro, 350 trans 3500 stall. 9" rearend w/ 513 rears. headers. comp 9000 1.76 rollers 850hp carb.
60' 151
1/8th mile 6.23 at 122
my 366 kicks ***..............
my built 388 with worked 882 heads headers. 650 carb. 488/501 comp cam.
350 trans w/ 4k stall 373 10 bolt rearend 12"x 30"x15" slicks
runs 7.60
Hi Keith, I know this 366T/427T subject is going to keep coming up with the shortage of 9.800" 454 blocks. The fly in the ointment will be 366 pistons. Can you post the mfg and part number of the pistons you used? Do you know if they're still available? I can visualize the 366 with one or a couple of boneyard Eaton blowers adapted.
  #23 (permalink)
Old 09-22-2009, 07:40 AM
Engine numbers
We have a 366 in ´67 Camaro and I would like to know what the stamped numbers in the front means.
It is T0221AHB.
I get the beginning Tonawanda February 21 but what stands AHB for?
Hope someone can help me.
  #24 (permalink)
Old 09-22-2009, 10:32 AM
Ahb
My book shows this to be a '74 366 with a 4bc from Chevy or GMC truck or school bus rated at 200 Hp. This all the info I have, hope it helps.
  #25 (permalink)
Old 09-22-2009, 10:50 AM
Building a 366 and not a 454, is like building a 283 instead of a 350. Makes sense sometimes, but most times not.
  #26 (permalink)
Old 01-02-2010, 01:08 PM
I have a 366 buss bloc, i overhaul them for the crank and rod, the bloc was bran rebuilt whit 0.030 flat top piston, i'm take deck bloc mesure it at 0.045 to 0.052 inch of deck to piston the head will be 1.86 in and 1.70 exh, open chamber oval port, 234 duration cam, i plan to 0 deck (0.045inch)of planing, port and polish 3 angle cut 1.96 intake 0.030 inch head planing, thumper comp camshaft torker intake 650 cfm carb headers bee a good hp for cruise and show very high torque low rpm
  #27 (permalink)
Old 04-02-2010, 12:05 AM
I'm trying to get an original one (less than 42000 on it) from a local tow truck driver. I want to put it in an 84 GMC K1500 4x4 with a 4spd. Good? Yes? No? I wanna make it a trail truck, so I think I will have enough torque with this motor, eh?
  #28 (permalink)
Old 04-02-2010, 07:45 AM
a 366 is a good engine. the's just no need to build one. it's the "305" of big blocks.
  #29 (permalink)
Old 04-02-2010, 08:34 AM
bondo's Avatar
Ayuh,... You can polish a turd, but it's Still a turd....
  #30 (permalink)
Old 04-02-2010, 12:21 PM
my87Z's Avatar
you must have gotten that quote from me. "you can polish a turd all you want but in the end you still just have a turd"
i would actually say that the 396 is the 305 of big blocks and that the 366 is the 265 of big blocks. it's just hard to make a bunch of power out of them cause the have a small bore
Closed Thread
