chevy 383 bent flexplate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-06-2006, 01:00 PM
So Im working on my chevy 350/383 getting it ready to mount (FINALLY) in the truck (49 Chevy 3 window). Im looking at the flexplate and notice that it looks a little strange. Looking down on the engine there is a noticable difference in space between the flexplate and the motor on one side. So I take it off and sure enough it has a small bulge at two of the mounting holes. Any idea on how this happened? It was externally balanced when I had the motor stroked, but I imagine that they wouldve checked to make sure it was still straight. The motor did sit on a tire (to keep it off the ground) with the flexplate bolted to it for about 9 months. Do you guys think I can run it still with no negative effects on the engine/drivetrain? It is such a tiny deviation but noticable nonetheless. I just dont want to have to get the rotating assembly balanced and tear the motor apart again or use this flexplate and have bad things happen. Thanks for any help from the hotrodders knowledgable!!!
-matt
Old 01-06-2006, 03:01 PM
If you used a turned down 400 crank , I would just get me a new flex plate for a 400 SB and use it . You should be able to see the balance weight on the old flex plate, that will tell you if its a 400.
Old 01-06-2006, 03:27 PM
there is a weight on the flexplate and yes it is a 400. but wouldnt i need to rebalance everything if i just replaced the flexplate? thx!
Old 01-07-2006, 01:22 PM
No rebalance ,just put a new one on and hammer down.
Flexplate 350 Chevy 153 or 168 tooth? Ghetto Jet Engine 5 05-18-2006 10:45 PM
SB Chevy Balanced 383 Stroker Kit from CNC-Motorsports.com bccsrc Engine 19 01-04-2006 07:51 AM
supplemental fuel injectors for 383 blown chevy stroker 383 Engine 8 03-24-2003 03:18 PM
Best blocks for 383 chevy, there is a difference roys63 Engine 20 03-20-2003 09:38 AM
chevy production 383 ronb Engine 21 01-05-2003 02:24 PM
