Chevy 383 / Flexplate Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 06:04 PM
fiftysix Chevy's Avatar
I would like to build a Chevy 383 for my 56 Chevy, but the headers that fit my price range will not work with the larger diameter of the externally balanced 168 tooth Flex plate. I need to stick with the smaller 153 tooth plate for the headers. Using heavy metal to internally balance the crank would drive the cost of the rebuilt beyond my means. I have contacted flex plate manufacturers like TCI, etc. and they were of no help. Anybody have a cure for this......
Thanks,
Jim
Old 03-02-2006, 06:13 PM
MI2600's Avatar
Member# 3287
I'm confused.
How can your headers be that close? Your former engine, provided it was a V8, was the same size as the 383. The flexplate has to fit within the outer dimensions of the block. And, the bellhousings should be the same.
Old 03-02-2006, 06:20 PM
Dear Confused,
The 350 that was in the car was bolted to a TH350, the internally balanced 350 uses a 153 tooth flexplate. Patriot Headers make a really nice set of coated 3/4 headers for this car, but Patriot says the headers fit so tight to the block that the larger dia. 168 tooth flexplate for the 400 crank used to build the 383 will hit the headers. That is the delimma!
Old 03-02-2006, 06:23 PM
I didn't mean anything bad with the "Dear Confused" part of my reply. When I reread the post, I see that it sounded crude. I apologize.
Jim
chevy block question joesnova2 Engine 15 05-01-2007 09:20 PM
383 flywheel choice question undy Engine 7 09-26-2005 06:32 AM
Help Building A Chevy 383. Skunk Engine 5 05-27-2005 09:37 AM
56' Chevy Rear Bumper Question maxie56 Body - Exterior 2 05-25-2005 09:11 AM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
