-   -   chevy 383 problem (http://www.hotrodders.com/forum/chevy-383-problem-178661.html)
sickolds 05-30-2010 08:12 PM
chevy 383 problem
i just built a chevy 383 and it dosent have big power like i though it would :confused:
Custom10 05-30-2010 08:37 PM
tell us what you built, just 383 is not enough info to go on.
sickolds 05-30-2010 08:44 PM
summit pistons 17cc dish vortec64cc heads eagle 383 crank 5.7 rods 224/224 summit cam flat lifters summit intake holley 750 vac sec
Custom10 05-30-2010 09:05 PM
OK so what is this motor in, what type of tranny, stall speed, rear gear ratio?
sickolds 05-30-2010 09:25 PM
trany is B&M th350 stock stall in a odsmobile cuttlas 1982 rear is stock i had a mild 350 in it and it was better from take off but not so good at high rpm
techinspector1 05-30-2010 09:43 PM
At 9.35:1 static compression ratio, the cylinder pressure may be a little light for a 224/224 cam. You may have been better off using a cam with 215-218 degrees @0.050" tappet lift. Either that, or use the 224/224 cam with up around 10.0:1 static compression ratio. Exchange the stock converter for one that stalls at 2500/3000. That'll get you past the soggy part of the cam. Put some gear in the rear, at least a 3.73.
Lose the Summit intake, replace with a Edelbrock RPM or Weiand Stealth. Bolt on some long-tube, equal-length headers with 1 3/4" primary tubes. Fabricate an X or H right after the collectors, use 2 5/8" or 2 3/4" pipes, through the mufflers of your choice, back to the rear bumper.
What did you do for valve springs? Are these L31 heads or aftermarket?
sickolds 05-30-2010 09:50 PM
were did that cop 9*** com from i was told it is 9.7 these is onky my second build
sickolds 05-30-2010 09:53 PM
yes sir these are vortec oem heads
cobalt327 05-30-2010 10:04 PM
It may well be- what is the quench at? If the block is zero decked, the CR will be about w/9.7:1 0.041" head gaskets. And should be OK w/your present cam.
cobalt327 05-30-2010 10:10 PM
If your rear gears are stock, chances are good they need to be changed to a lower (higher number) set. A torque converter to match the onset of serious torque production by the engine will be needed, something around a 3000 rpm stall range, give or take.
sickolds 05-30-2010 10:11 PM
1.433 pistons decke higt is stock
cobalt327 05-30-2010 10:27 PM
And what's the head gasket thickness? But I can tell you, this isn't looking good...
cobalt327 05-30-2010 10:37 PM
Something like 9.24:1 w/a 0.041 gasket, anyway. Given a 5.7" rod, 9.025" unmilled stock deck height, nothing subtracted for bearing clearance.
The 9.7 CR you were told would have been w/a zero deck and a 0.041 quench.
techinspector1 05-30-2010 10:44 PM
Are they bone-stock or did you change out the valve springs?
Custom10 05-31-2010 07:37 AM
diddo that
