Hey guys started this new post so there wasnt anymore confusion, Sorry bout that. I have a 94 c1500 roller block (638) fully machined for roller setup and fuel pump. The plan is to get a forged bottom end from howards. This engine is going in a 79 El Camino SS with a 4 speed Muncie Trans, and 3.73 gears. Below is a list of parts I am going to use to try and reach my goal of 500 HP and TQ around there also. What do you all think about these parts? Ill be coming to you all in the future for help and advise while building this and Ill also have pictures posted in the project journal.
Here are two parts list with dyno results. They are fairly the same but Im thinkin one of these would work. Also thinking about going with the E-Street EFI system.
http://www.summitracing.com/search/p...et-efi-systems
Horsepower:
503 HP @ 5500 rpm
Torque:
517 @ 4500 rpm
Engine:
383ci
Heads:
AFR Street 195 Cylinder Heads
Compression:
9.5
Carburetor:
Holley 0-4779 750 cfm
Ignition:
MSD Distributor 36° Timing
Cam:
Comp Cams 12-433-8 Hyd Roller Cam
Exhaust:
1 3/4" Headers
Fuel:
93 Octane Pump Gas
Horsepower:
491 @ 5500 rpm
Torque:
501 @ 4000 rpm
Engine:
383ci
Heads:
AFR 180cc Street Cylinder Heads
Compression:
9.5
Carburetor:
Ignition:
Cam:
Comp Cams 12-432-8 Hyd Roller Cam
Exhaust:
1 3/4 Headers
Fuel:
93 Octane Pump Gas
