Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 383 Roller Build (cont.....)
  #79 (permalink)
Old 02-15-2013, 09:15 AM
1Gary's Avatar
1Gary 1Gary is offline
Last journal entry: 383 dyno sym
Originally Posted by ChevroletSS View Post
Ok guys whats the rod and main bearing clearences supposed to be. I was told the mains are between .0015 and .0030. Never could find out about the rod bearings.
There are as you know a number of variables involved with this.Not that it matters much,but who's crank did you buy??. Just a question in ref to machining tolerances. Take nothing for granted.Measure everything.What does the crank manufacture tell you the clearances should be given your application??. Sometimes given who's crank you bought you find you have to use two different bearing haft's of different sizes to set the clearance's you want.
