Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 383 Roller Build (cont.....)
  #87 (permalink)
Old 02-16-2013, 10:54 AM
ap72 ap72 is offline
Banned
Originally Posted by barry425 View Post
As far as oil pumps go, I always take them apart before brazing the pickup to the pump. Also, I take the spring out and replace it with the Corvette spring. I get 60 psi at hot idle and no fluctuation (because of the big block pump having more flutes on the gears). The big block pump also is equal to the small block high volume pump.
As far as bearings, I use Clevite 77 on a hardened, stock (not reground), or nitrided crank. I use aluminum bearings on a crank that has been ground and not re-hardened or nitrided.
Glad to see someone besides me likes to have decent hot idle oil pressure. I've been getting getting burned at the stake for using HV oil pumps, but it really makes a difference in bearing wear, especially when you'll be running it at low rpm (like a street car).
I also use King bearings exclusively now, nothing against Clevite, I just think King is better.
