Chevy 383 Roller Build (cont.....)
Hey guys started this new post so there wasnt anymore confusion, Sorry bout that. I have a 94 c1500 roller block (638) fully machined for roller setup and fuel pump. The plan is to get a forged bottom end from howards. This engine is going in a 79 El Camino SS with a 4 speed Muncie Trans, and 3.73 gears. Below is a list of parts I am going to use to try and reach my goal of 500 HP and TQ around there also. What do you all think about these parts? Ill be coming to you all in the future for help and advise while building this and Ill also have pictures posted in the project journal.
Here are two parts list with dyno results. They are fairly the same but Im thinkin one of these would work. Also thinking about going with the E-Street EFI system. http://www.summitracing.com/search/p...et-efi-systems Horsepower:503 HP @ 5500 rpm Torque:517 @ 4500 rpm Engine:383ci Heads:AFR Street 195 Cylinder Heads Compression:9.5 Carburetor:Holley 0-4779 750 cfm Ignition:MSD Distributor 36° Timing Cam:Comp Cams 12-433-8 Hyd Roller Cam Exhaust:1 3/4" Headers Fuel:93 Octane Pump Gas Horsepower:491 @ 5500 rpm Torque:501 @ 4000 rpm Engine:383ci Heads:AFR 180cc Street Cylinder Heads Compression:9.5 Carburetor:Holley 0-4779 750 cfm Ignition:MSD Distributor 36° Timing Cam:Comp Cams 12-432-8 Hyd Roller Cam Exhaust:1 3/4 Headers Fuel:93 Octane Pump Gas Last edited by ChevroletSS; 12-21-2012 at 06:38 AM. |
I vote for the 503 hp and AFR 195 heads. In IMO the AFR 180 heads are more for a 355 ci engine. Good luck with your build.
Thanks guys Im sure Ill get back with you for some help on a few things. Tech Inspector got me intrested in those heads. What do you mean by: "If you share the ride with a better 1/2 maybe disconnect the secondary linkage on the carb. If you like shifting gears"
SS thats 2 separate sentences. I would disconnect the secondaries to limit power if my wife drove the car.She already spun out her Jimmy twice on the same hill and same corner.I threatened to enter her in "Canadas worst driver" TV show. Im getting better at cooking,,,,
The shifting gears thing is: If you used the smaller heads,to get the HP back use a slightly bigger cam,giving a little more on top end. This would give you the opportunity to drive it more like a sports car.I like engines that rev freely and that takes a little more cam timing,though not ideal,I think they are more fun |
I actually dont like how fast I have to shift in this car. I cant even count to 1 before I gotta shift to second and the same going from 2 to 3rd. But from third gear on to 4th its nice with what I have in it now but I cant imagine how its gonna be when I get this 383 in there. Might switch to a automatic. As far as rods go. What is the purpose of 6 inch rods compared to 5.7 inch?? Are 6inchers what are in 400sbc?? Im trying to figure out what rods Im gonna go with. Do you need shorter pistons with 6 inch rods???
The deflection angle of the rods at mid stroke compared to tdc/bdc.A longer rod will have the same deflection(determined by stroke) spread over a longer distance(rod length) a lot of unimportant math comes into affect,
what is the piston speed at different parts of the stroke what is the side thrust on the cylinder wall which one will produce more horse power(marginal under certain circumstances) If it was critical,we would all have 318 dodges |
What Howards told me,is they stopped building a 5.7 3.75 was because of thrust side load complaints.
| budget chevy 383 build | timaprt | Engine | 0 | 02-23-2012 03:53 PM |
| Engine break in question w/ roller cam? 96 Chevy 383 | chucksrt | Engine | 2 | 09-13-2011 06:56 AM |
| Hydraulic Flat or Roller??? Chevy 383 Street engine? | 89SDime | Engine | 38 | 02-23-2011 12:00 AM |
| 383 chevy build | RKipp | Engine | 5 | 09-12-2009 06:22 AM |
| 383 Build up....Roller vs. Mechanical | Steel | Hotrodding Basics | 22 | 01-04-2009 08:45 PM |
