Chevy 4.3 crank. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2009, 12:32 AM
DoubleVision's Avatar
Chevy 4.3 crank.
I`m curious to find out whats the safe max power limit on a non balance shaft chevy 4.3 V6 crankshaft. Since these cranks have split rod journals the amount of metal between the two is on the thin side. Can anything be done to make it stronger? Any word on this is appreciated.
Old 05-04-2009, 07:13 PM
Hippie's Avatar
Last journal entry: HEI comparison.
DV,
You need to check out the Syclone/Typhoon forums. Those guys will know if anybody does what the limts of the 4.3 are.
Chevy 4.3 balance shaft? grumpy1 Engine 6 05-13-2007 07:51 PM
overhauled chevy 350 will not crank poundst Engine 4 01-31-2004 11:44 PM
chevy 4.3 intake gaskets Bugsy Engine 3 12-12-2003 06:51 PM
crank for a chevy mudrunner81 Engine 2 12-29-2002 05:28 AM
Chevy 4.3 to 5.7 swap lanil4 Engine 4 12-26-2002 05:49 PM
