Chevy 4.3 high performance questions - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 08-14-2007, 08:50 PM
Hi all!
I have a '92 S-10 Blazer that I'm trying to get "right". I have installed all the bolt-in stuff: an MSD ignition (and NGK iridium plugs gapped at .065); Edelbrock headers; a Motorvation throttle body spacer; and a Jet Phase 2 performance chip (which I'm thinking about replacing with a stock chip because the codes are spitting out); a Fram AirHog air filter, etc.
The car has puffed out a smoke cloud since I got it - I'm pretty sure it's the valve seals. So I'm considering replacing the heads, and I would like to go with bigger valves. There used to be big-valve heads for 4.3's from Summit and other suppliers, but I guess it's a dying breed. Any suggestions?
Old 08-14-2007, 09:32 PM
redlightning's Avatar
Bob,This is for introductions.You might try posting your questions in the engine forum.Welcome to the site.
6 cyl chevy high performance stickshift Engine 5 11-04-2005 06:52 PM
high idle, small block chevy redneckgmc Engine 11 02-01-2005 07:19 PM
performance parts for Chevy straight six? rlackey Engine 6 01-28-2005 11:53 AM
SBC low performance Hi GPM questions LanceM Engine 5 05-21-2004 05:33 PM
high performance 283 steve Engine 2 06-22-2003 03:25 PM
