Hotrodders.com Streetbeasts lawsuit Beat the Beast -- defend free speech!
Streetbeasts lawsuit fundraiser
Goal: $10,000. Amount raised: $3,440.
Get the latest news on the lawsuit.
Thanks donors!
Click here to donate, or see more details about donating.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 08-22-2007, 05:33 PM
Proper Designs Proper Designs is offline
Business info in my profile
chevy 4.3 v6 dual exhaust
I'm building a rod with a 4.3 v6 motor. It should have about 270-290HP once im done building it. I just bought exhaust flanges and it's going to have 2" primary pipes for the headers. I want to run dual exhaust with an H pipe. What size tubing should I make the exhaust from. 2.25" or 2.5"? Thanks for your help.
Old 08-22-2007, 05:43 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Terrified Of 350 Rockets.
Since a 4.3 is a 350 with 2 less cylinders, either size pipe will work fine. The crossover pipe should be 75% of the diameter chosen. Since I built the 4.3 in my truck and added proformance parts, I`m curious what combo your using.
However, 2 inch primary pipes are way too big, they don`t need to be any larger than 1 5/8, 2 inch primary`s will kill bottom end power.
Old 08-22-2007, 06:11 PM
Hippie's Avatar
Hippie Hippie is offline
Streetbeasts lawsuit donor
Ditto what DV said.
I've never been crazy about duals on V-6's but there was an S-10 around here last year with a performance single exhaust that sounded really healthy.
Old 08-22-2007, 06:34 PM
so i guess i should reduce the primary tube diameter right out of the flages.
Old 08-23-2007, 12:36 PM
Ortie666's Avatar
Ortie666 Ortie666 is offline
I smell Clutch!
I have a set of s-10 headers in my 2.8L chevette witch is quite alot smaller than a 4.3. But headman used 1-1/2 primary's and a 2.5" collector so I just used 2.5 inch pipe all the way back, Here's a video of it with straight pipes http://videos.streetfire.net/video/...9500156e11b.htm
Here's another one with a 3.2Lstroker. The custom headers on this one are same diameters as the other one but this one has (custom)mufflers opposed straight's.
http://videos.streetfire.net/video/...87f00197eea.htm
Im very aware that 4.3L's sound nothing like 2.8L's being there 90* and 2.8L are 60* with a diffrent firing order.. but there still 6's... I figured it would give u an idea on what it might sound close to, may not be "AS" raspy as the 60*'s but its still there.. Dont use flowmaster 40's either ive heard bad stories about them on V6's
Old 08-23-2007, 12:52 PM
Holder350's Avatar
Holder350 Holder350 is offline
Auto Parts Professional
MICK!!!!!!!!!!!!!!!!!
How are you my brother vetter!
Old 08-23-2007, 08:28 PM
Vortech 4.3's Avatar
Vortech 4.3 Vortech 4.3 is offline
jack of all trades
i have edelbrock tes headers and y-pipe, into a 3 1/2" exhaust, dynomax round muffler, and a dump. when i go throught the cruise shows, everyone stops and looks. they can't believe its a 4.3.
Old 08-23-2007, 10:14 PM
Chevrolet4x4s Chevrolet4x4s is offline
Chevrolet4x4s's barnstar
Wiki editor
Last wiki edit: How to title a hot rod
I'm having some bad ideas .........anyway to get a smallblock into a vette
Shane
Old 08-24-2007, 01:36 AM
Ortie666's Avatar
I smell Clutch!
Dont meen to get off topic but
There's a way to get a 565 bowtie block into a chevette
http://groups.msn.com/ChevetteCentr...hoto&PhotoID=90
That's my buddys that lives down the street from me 900hp on motor 1500 with juice.. short wheelbase drag cars are scary tho
Old 08-24-2007, 06:12 AM
Holder350's Avatar
and a SBC will fit with the only modifacation being to cut the heating duct a bit to fit the HEI and move the radiator to the front of the bracklet, of course you have to run an electric fan, and it wouoldnt be a bad idea to flip it over and weld some SUPPORT under it, otherwise you might get a bit of TWIST , but it can be done without much hassle.
Old 08-24-2007, 09:26 AM
Wiki editor
Do you use s10 swap brackets or what?
Shane
Old 08-24-2007, 10:17 AM
Holder350's Avatar
you utilize your welding skills
Old 08-24-2007, 10:47 AM
Wiki editor
THAT SOUNDS EVEN BETTER what about headers
Shane
Old 08-24-2007, 08:02 PM
Holder350's Avatar
block huggers is realy the only thing that would come CLOSE to fitting, and even then you would have to have someone who wanted to fool with it to make the pipes work. it takes alot of doing but these do work , how ever the short wheelbase can make for a "wild" ride, I know that from experience.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "chevy 4.3 v6 dual exhaust"
Fors V6 vs Chevy V6 azdave Engine 4 02-04-2007 06:03 PM
Installing Dual Exhaust DodgeRam1500 Engine 2 01-05-2007 04:02 PM
55 Chevy 235 Split Exhaust Dual Intake Manifold drdislovely@aol.com Introduce Yourself 3 11-02-2005 01:19 PM
4.3 v6 CARGUY Engine 2 06-05-2002 06:17 PM
Chevy 4.3L V6 to 350 swap pitsen3 Engine 2 03-16-2002 09:22 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2010. All Rights Reserved.
