Chevy 4.3 Wire harness Tranny question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2013, 01:17 AM
I have a 4.3 vortec with a 5 speed manual Getrag tranny in a Nash Metrpolitan. The harness is for a 700r4. How can you splice in the correct connector and make it work with the computer?
Old 07-25-2013, 04:53 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Is the ECM you are running from the Auto matic setup?
Fact is stranger than Fiction
Old 07-25-2013, 08:22 PM
Tranny setup
Yes, the harness has a 700r4 plug.
Old 07-26-2013, 11:29 AM
What year Vortec are we talking here? The 1992-95 with the CPI injector or the 1996-02 with the CSFI?
CPI lower intake
1)
or like this
2)
Does your ECM have 4 connectors with approx. 24-32 pins in each connector labeled blue/black/red/grey?
If you are wanting the PCM to run with your 5 speed, you simply have to hook up the VSS vehicle speed sensor out of the 5 speed into the PCM.
VSS Low is pin #29 and uses a light green/black wire
VSS signal is pin #30 and uses a purple/white wire
Both these wires are located on the BLUE C1 connector with 32 pins.
The Shift Control Lamp is pin #15 with a tan/black wire on the Black 24 pin C4 connector .
peace
Hog
Old 07-26-2013, 12:03 PM
4.3 Tranny
The engine is from a 1991 S10, the tranny is the Getrag 5 speed. The two connecters are 24 and 32 pin. The tranny plug has blue, gray, tan/black
[IMG][/IMG]
[IMG][/IMG]
Old 07-27-2013, 02:07 PM
OK disregard ALL of my info, you have a TBI/4.3. Technically called a Vortec engine by GM, but you will get accurate info if you refer to the engine as a TBI 4.3 V6.
Your trans harness if its for a 700r4 will just have electronics for the TCC lockup and VSS(vehicle speed sensor).
91-92 4.3L S-10 & C/K Truck uses ECM 16144288 and 16143900.
And uses Program ID Byte Type(or Mask):$A0
Here is a pinout I found online for the S/T trucks 4.3 with TBI
peace
Hog
94 chevy 1500 tranny wiring harness identification needed kellydecaire Transmission - Rearend 3 07-03-2011 01:54 PM
wire harness wayneo Electrical 1 10-18-2007 05:59 PM
wire harness wayneo Electrical 5 10-15-2007 07:43 AM
Wire harness 1931 steve Electrical 12 12-15-2005 10:06 AM
wire harness for 49 chevy pickup 49dream Electrical 4 08-18-2004 04:53 AM
