Chevy 4 & 7 Swap Firing Order - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2005, 10:24 AM
These cams provide an exceptionally smooth torque curve and a significant decrease in crankshaft deflection.
The 4 & 7 swap firing order cams have been dyno and track tested in a variety of applications. Customers have reported an increase in horsepower over traditional firing order cams.
Thats the message from Comp Cams.
Fact or fiction ? How is the induction and exhaust systems effected?
Anybody got any good theories or opinions on this subject.
LeGerra Machine
Old 02-03-2005, 10:27 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I know thats an old trick. But I would think if it was really that great we would be seeing alot more of a cam selection with a 4/7 switch.
Old 02-03-2005, 10:41 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
I like the idea. The vortec heads are prone to cracks and it happens between the 5-7 cylinders often. This is b/c they fire one after the other creating a lot of heat in that area of the head. Also the intake runners are side by side and must draw against each other to some extent.
Old 02-03-2005, 10:45 AM
coldknock's Avatar
Changing the firing order didn't help any on a street/strip type engine. Some rag did a test and the dyno showed no measurable gains or change in the hp/tq curve.
Maybe it works for some folks with the resources to take advantage of it but most of of wouldn't gain a thing from doing that. They did say that the engine seemed to run a bit smoother, whatever that means.
Larry
Old 02-03-2005, 11:27 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I've tried them before and found nothing. Engine felt smoother with less vibration but he differences were negligable. Not to be confused with smoother application of power.
Old 02-03-2005, 11:55 AM
NXS's Avatar
NXS NXS is offline
http://www.motorsportsnxs.com/ohmy.gif
Or has anything really changed? Cylinders 4-2 now show the same problem.lol
Old 02-03-2005, 06:41 PM
lluciano77's Avatar
Ford did the same thing with the 302/5.0 change. The 351W also uses this "revised" firing order.
I put a 351W cam in my old 5.0. All you have to do is change the plug wires to match. The new cam was bigger, but I didn't notice any "magic" with the change.
Old 02-04-2005, 06:05 AM
Last journal entry: PICTURE TEST
cam swap
There is no silver bullit here... You now have cylinders 2 and 4 firing in sucession..... In any engine the average person would build there will not be any difference in hp..
There is a theory that in some of the larger CI engines that are at the end of the rope for finding HP the swap helps with the intake pulses and makes a tad bit more HP. But like the long connecting rod issue i have never seen real world numbers proving this....
Keith
Old 02-04-2005, 07:22 AM
Rice1965's Avatar
I would have to guess that if there were ANY advantage to swapping the order, the CUP teams would be doing it. In the racing forums I follow the topic has come up several times with the same result ... they tested and got no improvement.
