Chevy 400? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2005, 07:42 PM
Chevy 400?
I have a 65 chevy and when I got it the guy said it was a 400 I ran the casting #'s and it said it was a 350 the head # is 462624 which is a 350/400 76cc chamber 1.72/1.5,1.94/1.5, or 2.02/1.6 I'm not sure what valves is in it can someone please tell me what to look for to find out the valve size and is this a 400?
Old 07-23-2005, 07:44 PM
347mustang's Avatar
did you run the head casting number or the block number...?? where did you get these numbers at..on the head or block??
Old 07-23-2005, 09:08 PM
coldknock's Avatar
The only way to know what valves are in the head is to pull a head and measure them. What was the casting number onthe block?
Larry
Old 07-23-2005, 09:27 PM
tornado-tech's Avatar
If it is a 400, the last 3 numbers on the block will be either 509, 511 or 817.
Old 07-24-2005, 04:19 AM
I got the head # when I pulled the valve cover and the block # is 14010207
Old 07-24-2005, 04:52 AM
E.T. divided by $ spent= Speed
Thats a common passenger side dipstick 350 block #.1980-85
Old 07-24-2005, 10:24 PM
should I use those heads or the heads on my 350 now?
400 Chevy Blazin72 Engine 14 07-17-2005 10:57 AM
Chevy 400 Dead at full gas pcesak Engine 5 12-20-2002 10:30 AM
chevy 400 cid vortec tune port brnrubr Engine 1 11-20-2002 08:33 PM
Horesower for a 78 Chevy SB 400 sciaretta1250 Engine 3 11-14-2002 10:43 PM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 04:53 PM
