Chevy 400 Small Block to 350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2005, 07:51 PM
I recently purchased a one owner, 1978 Cheyenne, FWD, 400 turbo. The truck is in excellent condition inside and out. The only problem with it is that the small block 400 has a pretty good size hole in the oil pan that indicates an untimely departure of a piston rod. Knowing that I need to replace this engine, I would prefer to replace it with a 350 CID. Can anyone tell me for sure that this will be a straight swap? One of my concerns is the converter/flywheel. Any help would be appreciated.
I also have a 1976 Cheyenne and a 1981 Scottsdale. I have done a lot of restoration work on quite a few trucks, including a 1951 Chevy Suburban. I live in New Mexico and we still have some nice trucks here.
I can be contacted at jdt40u@yahoo.com
Thanks for your help
Chris
Old 07-19-2005, 08:08 PM
I can be contacted at [email]jdt40u@yahoo.com[/email
Chris
i know a site for you, it is www.67-72chevytrucks.com , it is for 47-98 chevy trucks, i am on the 73-87 message board part, put me as your referral, my name is the same there as it is here, 82c10
Old 07-19-2005, 08:39 PM
tornado-tech's Avatar
Here is a site for you to read up on. It should answer your questions. http://www.novak-adapt.com/knowledge...l_block_v8.htm
Old 07-19-2005, 09:16 PM
strikingthematch's Avatar
Pure American Muscle
Last journal entry: Still Going
If you swap in everything that goes with a 350 (dampener and flywheel/flexplate) you'll be fine as the engine are the same size...
If you have a running 350 you can stick in then i'd say go for it. Though I will say that you could rebuild that 400 with a new bore job and a rebuild kit. It would make a darn nice engine for your truck...
Chris
Old 07-20-2005, 11:19 AM
347mustang's Avatar
not to make you confused..i will be very clear....it is a direct bolt in...all small block chevys will bolt in...the 400 does have a diferent flywheel and balancer...so when you get the 350 make sure you use 350 balancer -flywheel or it will have a nasty vibration
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
how strong is a 350 small block ChevyVan Engine 18 01-04-2007 11:27 PM
400 small block re"performance"build 78 monte Engine 2 04-19-2003 07:32 PM
400 small block chevy bo 1972 Engine 1 12-24-2002 07:03 AM
Small Block Chevy 400 flexplate install novajohnb Engine 2 10-31-2002 03:53 PM
