Chevy 400 Stroker Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2007, 08:14 AM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
I was wondering what I would need for my 400 Stroker build...
This is what I was thinking....
400 Bored 0.030 over
flat top pistons 9.5:1-10:1 compression
Scat 9000 Pro Comp Stroker Crank
Chevy 400
3.750'' stroke
For use with 6.000'' rod
Internal balance
2-piece rear seal
I havent found heads yet
Any Input on this would be greatly appreciated
Thanks
Ed
I would also like to know where I could buy the flat top pistons in a full set. Ive been looking at jegs and all they sell them in is Individuals.
thanks again
Old 08-16-2007, 08:56 AM
GMC boogie's Avatar
I just wanted to make sure you knew that you were destroking your 400 from a 3.75 stroke to a 3.50. Is this intentional?
Old 08-16-2007, 09:09 AM
400smb_s10's Avatar
Back Yard Junky :)
No its not I ment to put the 3.75 stroke one on there sorry ill Edit it.
Old 08-16-2007, 11:10 AM
RippinRon's Avatar
Your not really building a stroker if your not increasing the stroke. Your just building a 400.
Old 08-16-2007, 11:15 AM
400smb_s10's Avatar
Back Yard Junky :)
Ok so what crank should I use to build a stroker?
Thanks
Ed
Old 08-16-2007, 12:55 PM
techinspector1's Avatar
Wiki Edits: 326
Let's start over at page 1.
A 350 is 4.000" bore and 3.480" stroke. (Stock).
A 400 is 4.125" bore and 3.750" stroke. (Stock).
A 383 is a 350 block overbored 0.030" for a finished bore of 4.030" and uses a crank with 3.750" stroke (either a 400 crank that has been turned down on the main bearings to fit into the 350 block's smaller saddles or a purpose-made aftermarket crank).
To build a stroker motor starting with the 400 block, you'll need a crank with a stroke longer than the stock 3.750" crank.
For instance, here's a 400 stroker kit that uses a 3.832" crank
http://www.speedomotive.com/ps-533-8...roker-kit.aspx
And one that uses a 3.875" crank....
http://www.speedomotive.com/ps-535-8...roker-kit.aspx
And one that uses a 4.000" crank (for use with aftermarket block....
http://www.speedomotive.com/ps-536-8...roker-kit.aspx
And one that uses a 4.125" crank (with aftermarket block...
http://www.speedomotive.com/ps-537-8...roker-kit.aspx
Old 08-16-2007, 01:33 PM
427v8's Avatar
C6, the C5 of tomorrow
Wiki Edits: 7
You can use a 4" stroke in a stock 400, you just have to clearance the block for the rods and use a small base circle cam and big cc heads to keep the compression reasonable.
You also won't get 6" rods in there, I used 5.875" rods and they were into the oil rings even though the ring pack was shorter than normal.
I'd expect someone would make a rotating assembly by now.
I did mine in the late 90's and no kits were available.
The speedo kits mentioned above look nice but lots o compression!
And the 6" rods work with tall deck or 'rocket block' motors only
It's pretty nice to have 400+ ft/lbs from 2400 RPM to 6000rpm
Keith
Old 08-16-2007, 02:08 PM
tornado-tech's Avatar
If you are wanting 6" rods with a 3.75 stroke, use h-beams as i-beams come too close to the camshaft as you will need as smaller base circle camshaft. As far as a full set of pistons, try JE, SRP, Wiseco, Ross or Arias pistons.
Old 08-16-2007, 03:25 PM
400smb_s10's Avatar
Back Yard Junky :)
So if I got the stroker crank and used 5.7 rods would It be a safer way? Im really looking forward to building a stroker Im just having a little bit of trouble understanding the concept of it all... Is it more stroke = more cubes? and more cubes = more horse power and ft lbs?
thanks for the help so far its appreciated
Ed <-- newbie to the stroker world
Old 08-16-2007, 03:39 PM
Tyler
I havn't built any 400 chevrolet's but I built a 428 pontiac and put it in a 1968 firebird. It has the same bore as a 400 with a 4.00 stroke. with a .030 overbore it came out to be a 434. It was a beast. I have pictures with both front tires about 6 inches off the ground with slicks. It only had 9.5 compression and I tried 87 octane in it one time without detonation, but I stayed out of the throttle. If they sell a good kit with a 4.00 stoke, that would be the route I would take. I promise you, you would have a painted smile on your face after your first drive. jtyler
Old 08-16-2007, 06:29 PM
hotrodf1's Avatar
Chasing dreams with a ball bat
Check out Competition Products!
They have full stroker kits, already balanced and ready to go!
415ci
421ci
434ci
Keep in mind that I had to clearance my block for Eagle H-Beam rods (and buy a special stroker pan with deep front end that barely clears the crossmember) with STOCK stroke of 3.75"
Old 08-16-2007, 08:14 PM
Wiki Edits: 326
"Is it more stroke = more cubes? and more cubes = more horse power and ft lbs?"
Yes
Old 08-16-2007, 09:39 PM
Jmark's Avatar
Hmmm, looks like building a stroker 400 is not really worth the money. You can bore a stock 400 out .060 and end up with almost the same displacement as the first speedo engine kit @2 grand! LOL
Old 08-16-2007, 11:08 PM
A 400 block bored .060 is asking for cracked cylinders and a hot running engine. Most machines shops won't suggest going over .040 on a 400.
Old 08-17-2007, 11:18 AM
I would go with a 3.875 stroke crank in a 4.155 bore 400 block. There are a few of those used in mud racing and they do rap well for the added stroke. I know of a Tracker that uses this setup and it is very hard to beat. It runs good enough to compete with upper 500+ cubes and has enough power to turn 40" paddles even.
Need small block chevy build ideas would like around 500 horse ssmonte Engine 17 08-03-2011 01:25 PM
Recommend me a build! 400 sbc, 64cc heads bunni Engine 4 03-17-2007 08:14 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
trying to build a 55 chevy tiresmoke55 Introduce Yourself 3 01-13-2006 07:11 PM
Just bought 400 chevy, build idea and some questions? Warrant Engine 10 01-11-2006 06:50 AM
