chevy 400 turbo trans output shaft question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2011, 07:38 PM
Hey guys I have a 454 H.O. engine that was in a 79 chevy pickup. The truck was 4x4 and I want to use the engine and 400T in my 57 chevy 210 streetrod but the output shaft(after removing the transfer case and adaptor) sticks out the back of the tranny case 1.25 inches and has 32 splines. Is there an extention housing that short or do I have to go through the trans and install a longer output shaft and housing? Anybody ever mess with this kind of thing? If so I'd appreciate any help. thanks
Old 05-22-2011, 07:59 PM
your gonna have to tear it down and swap output shaft and get a tail housing,but your short shaft is worth money so you could sell it
Old 05-24-2011, 01:11 PM
Can you tell me if any car 400 turbo output and tailhousing will work? I know there's different lengths, and also wondering about the inside part of the shaft are they all the same? thanks, I ain't scared
Old 05-24-2011, 04:59 PM
any one will work long or short tail chevy,caddy olds buick pont etc
Old 05-24-2011, 05:11 PM
anglia427 Thank you for taking the time to help.I am going to go for it.thanks for sharing your knowledge.
Old 05-24-2011, 05:23 PM
you could get a long tail bop cheeper than a short chevy from a junk yard thats what i would do also you wont need such a long drive shaft to make it work ie a chevelle or monte mid size gm would get you in the ball park.also give it a good rebiuld while your in there if i can be any help you can message me on here,ive ben at this for 40 yrs
Old 05-24-2011, 06:05 PM
anglia427 you are the man. Gettin up there and want to get this thing done before I kick if you know what I mean :-). I've had this 57 for a long time and it's been a little of everything over the years and now I just want to build a B B all chevy street rod. Thanks Man.
T-400 output shaft questions 327NUT Transmission - Rearend 4 11-19-2010 04:29 PM
700r4 trans output shaft question johnboy24 Transmission - Rearend 10 08-20-2009 04:46 PM
Different size output shaft on c4? nitrous_69stang Transmission - Rearend 3 04-17-2006 10:51 AM
th 400 ? output shaft 54chevrat Transmission - Rearend 4 09-29-2005 06:44 AM
C5 output shaft loose k2mooch Transmission - Rearend 1 03-17-2004 04:50 PM
