Chevy 427 3x2 Porblems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2002, 12:51 PM
Post Chevy 427 3x2 Porblems
I have been having problems tuning my car here are the symtems:
1. Idle: 750RPM I have little to no vacuum. timing set at 2 degrees TDC (I will expain why later) once vacuum hooked back up it dose not advance. If I turn idle up to 1200-2000RPM Vacuum picks up rapidly 12-14 lbs (Suspect leaning out at higher RPM low idle is very rich)
2. Cruising: 2500 - 3500 RPM car surges terribley disconnected vacuum advance pluged line runs smoother. Found if I devance the timing to 2 degrees TDC and run with a B20 pot it will perform a better (suspect leaning)
3. Full throtle cruising: 3000 - 4500 RPM breaks up some pinging. (suspect leaning)
Equipment
*427 bored .30 over (originally 400HP 3x2)
*3x2 Holleies. 1x list 4056 2 x list 3659 (originals)
*Aluminium Intake rectagular ports 39377797 (435HP)
*left head 3918840 & right 3919840 rectports (435HP)ported stainles valves comp springs made to breath better over stock.
*stock exhaust
*High Energy Comp cam grind number 268H-10 amd lifters
*Cloyes roller timing chain
*K-66 breakerles magnetic TI (Have moderne module and wiring harness from M&H electric)
I am suspecting I need to rejet my Primary carb do to engine braething improvements please let me know what you think. Thanks in advance.
Old 06-01-2002, 02:44 PM
Post
Do a plug chop. This should give you a good indication on your jetting. The main jetting on your primary has to be right first. Low or no vacum suggests a very rich mixture or a leak.
powerjunkee
Old 06-01-2002, 08:13 PM
4 Jaw Chuck's Avatar
Post
Where are you checking vacuum from, ported or manifold? It sounds like you are checking ported vacuum which is taken from above the throttle plates. This is where you hook up vacuum advance for the distributor, having 0 vacuum at idle there is normal-you don't want advance until the throttles are opened right!? Perhaps you have the vacuum lines mixed up and have manifold vacuum going to the distributor this will cause pinging at light loads. Check manifold vacuum and tell us what that is before you go any further. What color are the plugs? Your initial timing should be at least 6-8 degrees.
— Han Solo
Old 06-04-2002, 12:04 PM
Post
I checked Manifold vacuum. at an idle it was between 11.5-14lbs. as it dropped down it ran rougher. Turned idle up to 2000RPM 18-20lbs. It would pop and vacuum would drop to 18 and pick up again. Is it recommended to run the vacuuum advance on the vacuum port (Off Carb) and not direct to the manifold ? I squrtied either all over the intake and no leaks. Next I will try to block all vacuum intakes perhaps I have a bad leaky hose.
Old 06-04-2002, 04:25 PM
Post
Check the following,
-Initial timing.
-Idle mixture.
You vacuum advance should come from a ported vacuum source off the carb.
— Han Solo
