Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 454 FI propane add on system
Old 07-19-2011, 03:33 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi Fred
Welcome to Hotrodders.com Glad to have you with us.
In order to use the propane, it would be easier & cheaper to change the TPI to a carburetor & use it that way. To use it with the TPI you would have to alter the computer to turn the fuel pump off & reset the timing. Also you'd either have to have the propane at a high pressure, or cold enough to keep it liquid, as the injectors can't meter vapor.
Rich
