Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 454 FI propane add on system
Old 07-19-2011, 06:57 PM
vtflatlander1 vtflatlander1 is offline
propane add on
Thanks Rich I will keep that in mind. If I go to carb I would still have to disconnect fuel pump or change computer correct. Regular or electric low pressure fuel pump would be needed for the carb to run properly. If I did go to a carb what would the set=up be for the propane parts
