Chevy 454 FI propane add on system - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2011, 07:20 PM
I have a 1995 454 CI Fuel Injected engine in my motorhome. I am looking for a propane add-on system so I can have the option of running gas or propane. I had one in a 454 carbed engine that worked great. Anyone know of a kit or parts I would need. I would like to do the work myself. All help and information very well appreciated
Thanks
Fred
Old 07-19-2011, 03:33 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Fred
Welcome to Hotrodders.com Glad to have you with us.
In order to use the propane, it would be easier & cheaper to change the TPI to a carburetor & use it that way. To use it with the TPI you would have to alter the computer to turn the fuel pump off & reset the timing. Also you'd either have to have the propane at a high pressure, or cold enough to keep it liquid, as the injectors can't meter vapor.
Rich
Old 07-19-2011, 06:57 PM
propane add on
Thanks Rich I will keep that in mind. If I go to carb I would still have to disconnect fuel pump or change computer correct. Regular or electric low pressure fuel pump would be needed for the carb to run properly. If I did go to a carb what would the set=up be for the propane parts
Thanks
Fred
Old 07-20-2011, 12:09 AM
Click the link & give them a call.
Rich
http://www.impco.ws/IMPCO-catalogs.asp
Old 07-20-2011, 12:12 AM
Give Technocarb a call also. They do the the direct port injection systems.
chevy 350 on propane wont start!!!!??????? Codyw Hotrodding Basics 4 08-16-2010 07:06 AM
Cooling System-Open System vs Closed System smokey626 General Rodding Tech 4 02-14-2009 07:34 PM
454 chevy to propane wiscrainman Engine 1 06-15-2008 08:45 PM
chevy inline 6 on propane McLeay F1 Engine 1 11-04-2007 09:04 PM
97 Chevy Vortech on propane?? scheetz93 Engine 5 06-09-2004 07:25 PM
