-   -   Chevy 454 HELP!!! (http://www.hotrodders.com/forum/chevy-454-help-224364.html)
rwrambo2 09-25-2012 11:41 AM
Chevy 454 HELP!!!
3 Attachment(s)
Does the numbers stamped on the piston tops mean that the cylinders have been bored?
I cannot find what that suffix code is. I have never seen one stamped FBH. Could this be a crate engine from Tonawanda?
cdminter59 09-25-2012 11:55 AM
Chevy 454 HELP!!!
The part# for the piston is usually stamped on a pad underneath the piston. On the very top some are marked std,.030,.040, and .060. I can't help you on the FBH suffix. I looked on several different websites with no luck.
RWENUTS 09-25-2012 03:05 PM
Maybe someone re-stamped the block and got it wrong.
I found a TBH. 1970 truck 402.
What's the casting number?
BOBCRMAN@aol.com 09-25-2012 04:05 PM
Not factory numbers on piston tops. Probably re-rung by someone that stamped numbers to get correct piston/cylinder placement.
rwrambo2 09-28-2012 11:40 AM
The casting number is
14015445
RWENUTS 09-28-2012 04:36 PM
It's pic time!!
I can't find that number anywhere.
Lets see this 454!!
cobalt327 09-28-2012 05:47 PM
The factory has used numbers, letters, and symbols to designate different weights and sizes for use during assembly. The block is also often marked for size. This compensates for the slight variations in bore size that occurs during production and allows the workers to select the correct piston for the bore w/o needing to remeasure each hole and piston.
As for the stamped in TO928FBH, this does resemble the suffix code line found on the passenger front of the block. If it is, that's the first time I've seen it there. Doubt it was factory, if anything it was done to ID the pistons to that block. Lot of trouble to go to when a simpler method could have been used, IMO- but who knows.
rwrambo2 10-01-2012 12:17 PM
5 Attachment(s)
These are pics of the numbers on the block.
