Chevy 454 HELP!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2012, 11:41 AM
Chevy 454 HELP!!!
Does the numbers stamped on the piston tops mean that the cylinders have been bored?
I cannot find what that suffix code is. I have never seen one stamped FBH. Could this be a crate engine from Tonawanda?
ID:	68128   Click image for larger version
ID:	68129   Click image for larger version
Name:	New Image1.JPG
Old 09-25-2012, 11:55 AM
Chevy 454 HELP!!!
The part# for the piston is usually stamped on a pad underneath the piston. On the very top some are marked std,.030,.040, and .060. I can't help you on the FBH suffix. I looked on several different websites with no luck.
Old 09-25-2012, 03:05 PM
RWENUTS's Avatar
Maybe someone re-stamped the block and got it wrong.
I found a TBH. 1970 truck 402.
What's the casting number?
Old 09-25-2012, 04:05 PM
BOBCRMAN@aol.com's Avatar
Not factory numbers on piston tops. Probably re-rung by someone that stamped numbers to get correct piston/cylinder placement.
Old 09-28-2012, 11:40 AM
The casting number is
14015445
Old 09-28-2012, 04:36 PM
RWENUTS's Avatar
It's pic time!!
I can't find that number anywhere.
Lets see this 454!!
Old 09-28-2012, 05:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The factory has used numbers, letters, and symbols to designate different weights and sizes for use during assembly. The block is also often marked for size. This compensates for the slight variations in bore size that occurs during production and allows the workers to select the correct piston for the bore w/o needing to remeasure each hole and piston.
As for the stamped in TO928FBH, this does resemble the suffix code line found on the passenger front of the block. If it is, that's the first time I've seen it there. Doubt it was factory, if anything it was done to ID the pistons to that block. Lot of trouble to go to when a simpler method could have been used, IMO- but who knows.
Old 10-01-2012, 12:17 PM
These are pics of the numbers on the block.
ID:	68213   Click image for larger version
ID:	68214   Click image for larger version
ID:	68215   Click image for larger version
ID:	68216   Click image for larger version
454, chevy 7.4l, chevy big block, chevy suffix codes, engine identification
454 chevy 54deadsled Engine 1 04-23-2009 09:36 PM
HELP ME.. 454 chevy how to,,please!!! propaine rockcrawler Engine 8 03-06-2007 08:23 AM
454 in 57 Chevy Dingo49 Engine 3 05-25-2006 10:47 AM
454 in 56-57 chevy TtopIroc Engine 5 09-24-2002 11:15 AM
CHEVY 454 BB reggiesr Engine 2 10-23-2001 05:05 PM
