chevy 454 manual transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2010, 02:46 PM
hi i am replacing my old tired 350 out of my 73 4x4 pickup with a 454 form a 89 crew cab auto. my question is can i use the 4 speed manual that was mated to the 350 on the 454 if i get the right flywheel, bellhousing etc.
any help is much appreciated
thx
Old 05-06-2010, 02:56 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
should be able to
just remember 454 is externaly balanced
Old 05-06-2010, 04:38 PM
ericnova72's Avatar
More for Less Racer
If the manual trans behind the 350 was using a 11" or 12" clutch, all you need is the 454 external balance flywheel and the clutch will bolt right on. Bellhousing is the same between the two motors. This is an easy swap due to Chevy's interchangability.
Old 05-06-2010, 08:33 PM
awesome thanks alot guys
Old 05-06-2010, 09:20 PM
one more question, if i cant get ahold of a flywheel for the 454 can i use a balance plate with the 350 flywheel?
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
The Manual Transmission Saddens Me. LittlePwny Transmission - Rearend 24 04-28-2009 06:23 PM
5.0 to 7.4 swap Tilar Engine 7 02-09-2008 07:51 PM
what manual trans for 1/2 ton chevy????? kuhn-77 Transmission - Rearend 3 07-28-2007 02:20 PM
Engine build ideas Rug Engine 23 12-25-2006 02:39 PM
