chevy 454 not shifting from first - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 05:25 PM
Hello there,
i recently bought a 1980 chevy k20. i drove it home from about 25 miles away and it drove just fine. but the speedo didnt work and it didnt have a tach. the other night i installed a tach and just ran both seperate wires to reactivate the speedo, but i havent ran the truck yet. i took it out the other nigt after i installed the tach and it wont shift from 1st gear. the tranny has 3 gears and to be honest i dont know much about the truck, its my first work truck. i just added about 3 quarts of tranny fluid and just changed my oil and filter. when i put the truck into gear it shakes the truck very hard, its an automatic, so when i put it into drive. and then when i put it into reverse it knocks even harder. it is also starting to rev very high 1000-1500 rpms when i start it. it jsut sounds abnormally loud. basically the truck wont shift from first gear but it was shifting perfectly fine just the other day when i drove it home. can anyone help me please!?!? thank you!!!
Old 03-10-2013, 06:06 PM
Why did you add so much tranny fluid? Three quarts at one time seams like a awful lot? Have you checked the dip stick on the tranny after its started to see what the level is. It possible you over filled it.
Old 03-10-2013, 06:37 PM
okay i only added a quart and a half but i think i did over fill the trans fluid. what happens if i over fill the tranny fluid? and what can i do if it is bad for the engine or tranny? thank you!
Old 03-10-2013, 07:24 PM
I wouldn't think that much would of caused you those kinds of problems unless it was over filled to start with. You need to start it and check the fluid level. Sounds strange, but I seen some strange tranny problems with over filling trannys. Did you check the tranny fluid level when you bought it or after you got home?
Old 03-10-2013, 07:34 PM
Banned
this type of problem sounds like the wrong type of trans fluid. On over fill of a quart or two you will most likely blow a seal or two. Is this a stock motor and trans? Or is it someone creation?
Old 03-12-2013, 03:25 PM
1badLemans's Avatar
I would first check your fluid level in your trans. Check it when warmed up and at idle. Second check the vacuum line from carb to vacuum modulator on the trans. Its on the passenger side of the trans. Sounds like it might have fallen off and you caused a vacuum leak. Then check back with us.
2000 chevy s10 2.2 not shifting charles l Transmission - Rearend 10 09-18-2011 01:47 PM
94 chevy, 5.7 tpi with trans shifting problems chevybyheart Transmission - Rearend 4 07-06-2010 02:41 PM
85' chevy 4spd not shifting~! chlsnk Transmission - Rearend 7 04-15-2009 04:00 PM
2000 Chevy S10 shifting trouble Mike22 Transmission - Rearend 6 01-02-2009 07:30 PM
88 chevy c1500 not shifting Help!I scheetz93 Transmission - Rearend 3 03-08-2006 11:46 AM
