Chevy 454 Spark Plugs Selection Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2006, 08:56 PM
72NOVA454
Help
let's pretend a "friend of mine" has just rebuilt his 454 (actually a 468) BB Chevy street/strip car and needs some spark plugs. The block is from a 79 chevy truck and the oval port iron heads from a 69-70 passenger car. Compression is approximately 10:1. He has MSD capacative discharge "CD" ignition, headers, long duration cam, etc.
what spark plug do I start with?
My "friend" currently has the AC-Delco R45XLS plugs in there now. The motor runs fine - so it appears, but I believe there is a more correct plug for the application. I think the plugs are running hot. Where do I begin the process of plug selection? Lets just say a performance 454 Chevy just showed up at your front door one day (yea right !) with no spark plugs in there. what would you do to select the right plug?
Old 09-28-2006, 10:20 PM
topfuel's Avatar
ASE Certified Master Machinist
Last journal entry: More Pics
leejoy, as I recall most standard performance big block chevys that use the large gasketed plug, used a AC 43N plug. Since these aren't made anymore, the XLS series is what is sold as a replacement. The high performance engines (L-72, L-88, etc.) used the 42N or 42XLS (fully threaded) in aluminum heads. Try the 43XLS and check your plugs to see what they look like after a few full power runs. That's what I would do to my door step 454.
Old 09-28-2006, 10:28 PM
bigblock454camaro's Avatar
No substitute for cubic inches
Last journal entry: 31 Tudor
I'm currently running autolite 144 plugs in my 454 right now.
Old 09-28-2006, 11:29 PM
Bumpstick's Avatar
Hammer and a torch
I`m with bigblock454camaro...
Run the Autolites or the same plug in Motorcraft... I`m a Chevy person all the way except for the plugs... BBC`s and AC Delco just dont get along all that well...
Old 09-29-2006, 03:14 AM
Guy Hiltz's Avatar
All I've been using in my LS-6 big block are AC Delco R 43-T plugs for the last 5 years,they seem to work just fine,although they get replaced every year.
Old 09-29-2006, 05:26 AM
72NOVA454
thanks buddy. I'll do that.
Old 09-29-2006, 05:29 AM
72NOVA454
I will try to compare the heat range of that plug to my current plug, then make a decision.
Old 09-29-2006, 07:04 PM
454 plugs
In the Chiltons auto repair manual 1969 to 1976 it states that a 1971 454 takes a r-42ts plug, 1972 takes a r-44t,up untill 1974. A1970 454 takes a r-44t.
Old 09-29-2006, 08:07 PM
72NOVA454
that's the kind of info I was looking for. Thanks buddy. I will also check on the gap - it may be .035" I think.
Old 09-29-2006, 08:41 PM
72NOVA454
dear ChevMal
can you check the book again and see what plugs are used for a 1969-1970 chevy 396 or 427? (101 cc comb chamber)
thanks buddy.
Old 10-01-2006, 09:37 AM
Leejoy-454
Leeyjoy, e-mail at chevmal@aol.com
Old 10-01-2006, 09:47 AM
Leeyjoy-plugs
The 1969 427 big block rated at 335 hp takes a r44n pulg. With 390 hp takes a r43n. The 1970 454 with 345 hp takes a r44t.With 390 hp takes a r43t. Al
Old 10-02-2006, 12:05 AM
72NOVA454
I learned there are 2 different size (length) plugs for this application. It is tricky. My heads are from a 1969-1970 passenger car per the casting number. the block is a 1979 chevy truck. I need the plugs with the "long" threaded portion not the "short". I went to a parts store and had them show me a bunch of plugs. I finally got it figured out. I went with the AC-Delco R43XLS plug. It was not easy to choose. the computer showed at least 15-20 different plugs available. the plug I got is the same size physically as the plug I was running but with a lower heat range. My old plugs were the R45XLS and were "hotter". Also the new plugs have a gap at .035" per the computer listing while the older plugs were gapped at .025" which I believe was incorrect.
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
2.8L spark plugs for 1986 s-10 catscan4free Engine 3 02-23-2004 02:33 PM
Question Performance spark plugs for 98 mustang gt sungho General Rodding Tech 11 08-14-2003 01:00 PM
Spark Plugs Francis Engine 6 07-28-2003 12:22 AM
spark plugs richie rich Engine 2 09-24-2002 05:28 AM
