Chevy 454, What to do? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2007, 09:41 PM
I'm getting a free running Chevy 454 and want to build a cheap 1/4 mile car or truck. What would you do with this engine? I'm thinking new rings, bearings, and oiling system and intake. Does anyone have a 454 and a timeslip time to share.
Old 01-23-2007, 09:48 PM
Bumpstick's Avatar
Hammer and a torch
Just depends on how deep your pockets are...
Also as to whats already in the 454...?
Old 01-23-2007, 09:57 PM
I will let you know when I pick it up. But it's running so I plan on running it after a MILD build. I don't want to put more than $350 in parts in it. And I want to run it right away because of a small budget with new rings and then make changes. It will be a dragstrip only car.
Old 01-24-2007, 06:59 AM
firestone's Avatar
http://teamrfc.gospelcom.net
The casting numbers on the heads will have a lot to do with how much power is possible.
Adam
Old 01-24-2007, 07:46 AM
Most likely a very low compression engine (7.5:1 cr) with the stock pistons and heads. In order to run a long duration cam, the compression will need to be raised a lot. If you have 781 or 049 heads (123cc) then swapping them for some 112cc semi-open heads (820's) would help get the compression up to 8.0:1. You should be able to run a moderate cam with 8:1cr, like 210 to 220 degrees duration at 0.050". 220 degrees isn't a drag racing cam but it is much better than stock . Otherwise, you will need some new domed pistons.
For a drag only engine, you should try to make about 10.5:1 cr and use a cam with about 240 to 250 degrees duration at 0.050". Of course this will also require stronger springs, push rods, and rocker arms. BBC's eat cams so makes sure to use diesel engine oil for more protection. Better rod bolts will also be a good idea.
Then you will need a better intake, carb, and a set of headers. Then you will need a high stall converter if it is an automatic transmission and lower gears with a LSD center section if you plan to get any traction at all. So, it looks like you will need to multiply your budget by at least ten times to get it going.
Another option would be to spray a 300 hp shot of n20 on that engine in it's current configuration. That could get you some pretty good times at the strip for about 350.00.
FYI, you could find some cheap BBC racing parts (intakes, carbs, headers, ect) at your local swap meet.
Old 01-24-2007, 07:54 AM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
What about putting a mild street cam in his motor and milling the heads down to get about 9.0:1 out of it? Maybe something like an XE274?
K
Old 01-24-2007, 03:12 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
You need to find out exactly what you have, heads, block, etc. Which deck height block is it?
You can easily go anywhere from 300 hp to 800 hp, how much $$$$$$$$ is in those pockets????????
Cheap and BIG BLOCK don't fit together. Consider what you have and what you want.
If you start hopping up a truck engine, figure $ 15 per total horsepower until you get up there a ways, then $ 20 per total horsepower.
If you figure hop up stuff only ... figure $ 35 per horsepower added.
Old 01-24-2007, 03:20 PM
xntrik's Avatar
K
If its a real low compression engine you can't get 9/1 by milling.
Even if you could, what you are suggesting will cost $1000.
Milling the compression surface, milling the intake surface, notching the pistons, correcting the valve train geometry, special pushrods, etc. Then the headers might not fit.
He should bore it and go good pistons.
But all we are doing now is speculating about a hypothetical situation.
Old 01-24-2007, 03:27 PM
runn141's Avatar
if compression is that low, supercharge it?
Old 01-24-2007, 04:33 PM
DeathRattle's Avatar
Some Punk Kid
He says he only wants to spend $350. Which elimantes every thing you could possibly do besides basic rebuild and maybe wax the fan blades.
350 is not a realistic budget for a drag only car. To be completely honest.
Old 01-24-2007, 08:30 PM
Hey thanks for all of the advice. I dont want to spend alot right up front. But I want to build a solid short block, then move on from there. Does anyone have any information on the $310 kit from Powerhouse? What is it's compression? The engine is in a 1985 3/4ton pickup. I will give numbers when I pick it up.
Old 01-24-2007, 08:43 PM
What can I do to improve it because it only has 230HP! HELP!
Old 01-24-2007, 08:46 PM
poncho62's Avatar
Wiki Edits: 5
You are gonna need better heads..........................gotta breathe better.
Old 01-24-2007, 08:48 PM
What casting numbers are the good ones?
Old 01-24-2007, 09:06 PM
They are 336781 I think. Or thats what the internet says.
Chevy 454 Sensors flyfishingpage Engine 1 02-03-2012 06:58 PM
454 chevy in 79 trans am, possible? Trans Am Benny Engine 9 12-31-2011 11:06 AM
Chevy 454 overheating no matter what I do rakundig Engine 26 02-13-2011 04:03 PM
Chevy 454 PCV and Vacuum question rakundig Engine 7 10-29-2003 08:33 PM
Chevy 454 to 489 Question Project 64 Engine 3 11-05-2002 03:58 PM
