chevy 461 vs 462 heads which one flows better - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2008, 08:46 PM
Hi guys i hope you can help me i just want to know which set of chevy camel hump heads flow better the 461 or 462 im bearly going to start to rebuild my engine i still need alot of parts to finish my project but i want to know if i can use either of those heads to see 500+ hp im going to be using a casting # 3970010 block. Thanks
Old 03-23-2008, 09:08 PM
They both have the same ports. the difference is the combustion chamber the 461 has a 64 CC chamber and the 462 has a 68CC chamber, I would not use either unless I had them and the guides were in good shape if I had to buy a set get the SR torker from Dart they make good power for less than puting valve guides and screw in studs/guide plates in the 461/2 heads.
Old 03-23-2008, 09:38 PM
so either of those heads can make 500+ hp
Old 03-23-2008, 09:47 PM
Jmark's Avatar
Very unlikely.
300hp is easily achieved with stock heads.
400 maybe, MAYBE, with some very serious porting and valve work, on a good day.
For 500hp, you'll need some aftermarket big port heads and carefull selection of the cam and pistons.
Old 03-23-2008, 10:06 PM
[QUOTE=Jmark]Very unlikely.
For 500hp, you'll need some aftermarket big port heads and carefull selection of the cam and pistons.[/QUOTE
have you heared of the chevy 3947041X heads are they any good
Old 03-23-2008, 11:08 PM
Casperdude898's Avatar
i kno for a fact the 461 heads can make 500+ hp. me and a buddy just built a nova with the same heads and cut the valves to 2.02 and 1.6 (with a little porting done) and he is pushin over 500 hp
Old 03-23-2008, 11:12 PM
Jmark's Avatar
I would be curious to know the specs of the build and see the dyno sheet.
Old 03-24-2008, 02:33 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Agreed ^^^
Getting stock heads into the 500hp range usually requires twice as much as the cost of aftermarket heads. Its possible, but it would be pretty foolish to waste money like that.
Old 03-24-2008, 12:49 PM
406 ss monte's Avatar
eat a beaver, save a tree
the 461 has a 64cc chamber & the 462 has a 68cc chamber. the 461x has a little bigger intake port (170 v/s 160) & the 041x has a 68cc chamber with a 170cc runner. with 2.02-1.6 valves & the right valve job & a little bowl blending you should be able to get 400-450 horespower out of any of them.
Old 03-24-2008, 03:00 PM
MI2600's Avatar
Member# 3287
Can you give me a source for the chamber volumes of 68cc for the 462 and 041 heads? Everything I've seen has them at 64cc.
Old 03-24-2008, 03:08 PM
honestly i don't remember where i seen or heard that. you can look & see the difference. they are a different size. a buddy of mine ran dirt track for years & was also a machinist. i seen him angle mill a 461 & a 186 & ran them on the same engine. maybe he told me that they were 64 & 68 . the 461 might be a 58cc & the others 64cc.
Old 03-24-2008, 06:51 PM
King of my Man-cave.
461 and 462 heads have different chamber sizes for the different valve sizes originally installed in them. The 2.02/1.60 heads had AROUND 64cc while the 1.94/1.50 heads had AROUND 58cc. The best thing to do is to cc any head that you have so you know EXACTLY what you are dealing with. Published specs can be way off.
tom
Old 03-24-2008, 06:58 PM
Especially when the configuration you're interested in occurs over an 18 (or so) inch length and is the product of sand casting technology. Good sand castings for their time, I agree, but there was never any attempt I've noticed to machine to balance-out the chamber volumes.
Pat
Old 03-24-2008, 07:11 PM
i have never seen a 461 or 462 casting that was stock, less than 64cc, i have a virgin set of 041 in the shop right now and they are 66cc. from what i have seen over the years these heads range from 64 to 67 cc
sam-missle
Old 03-24-2008, 07:27 PM
which heads are better
which of these heads are better if it has everything you can do to it valve job, porting, hardened seat and everything else i mean pretty much everything you can do to these heads which one would be better or which other casting #'s would you guys recommend me that are gm cast iron heads
461, 461x, 462, 186, 041, 041x chevy heads any info is good about these heads . Thanks
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
AFR or Vortec heads? Cam? rodent Engine 18 06-08-2010 03:50 PM
Chevy Small Block Heads druss32 Engine 17 05-10-2006 08:35 PM
Chevy Twisted Wedge Heads Blazin72 Engine 12 07-29-2005 02:54 PM
85 chevy 305 heads on an 89 TBI chevy 350? jazzguitar Engine 4 11-03-2002 04:11 AM
