Chevy 4l60e slipping problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2010, 09:22 PM
I have a 96 chev k1500 with a 4l60e trans. Recently during the start of our cold weather I noticed a slight slip in the trans at start up. After I got going everything seemed fine. Just wanting info on what this could be that I need to look for and possible steps to troubleshoot scenarios as to probable issues. Trans was replaced approx. 25000 miles ago.
Doesn't seem to be mechanical so I am thinking electrical. I haven't noticed any check engine light either.
Just looking for a starting point to look this over before it gets worse
Thanks
B
Old 01-01-2011, 09:47 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks
B
that trans could have a problem with the EPC solenoid. Some how I doubt that at this point
check the fluid level? Colder temps bring that problem to lite
4L60E TCC Slipping when cold only monette999 Transmission - Rearend 24 11-24-2010 10:00 AM
4L60e slipping in 2-4 elwrencho Transmission - Rearend 7 12-01-2009 07:09 PM
4l60e slipping in reverse tabascojohn Transmission - Rearend 3 09-15-2009 06:57 AM
4l60E slipping in OD ratitak Transmission - Rearend 10 04-02-2009 10:52 PM
4L60E Slipping bluesman123 Transmission - Rearend 10 07-18-2008 11:21 AM
