Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Chevy 4l60E trans. Question
Old 04-17-2006, 08:16 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
A TransGo 4L60E - HD2 kit will firm up stuff. A vette 2nd gear servo also helps.
The TransGo kit will give you control over down shifting to 1st gear . I can run my 5.3 Silverado against the rev limiter then clik off another gear manually
