Chevy 4l60E trans. Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 08:13 AM
If you wanted to change the shifting of the 4l60E. From stock to a firm shift shift. And also to be able to hold it in gear longer.Would a good shift kit be enough ? Change the valvebody ? And or increase the line pressure ? Also which brand name do you think is better ?
Old 04-17-2006, 08:36 AM
The 4l60E is electronically controlled, so you'll need a chip or manual controller that plugs into the wiring harnass. You can go on Ebay and look for shift controllers. Theres a company in Texas that sells all transmission parts, Makco Dist. www.bulkpart.com. Check with them.
Old 04-17-2006, 07:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A TransGo 4L60E - HD2 kit will firm up stuff. A vette 2nd gear servo also helps.
The TransGo kit will give you control over down shifting to 1st gear . I can run my 5.3 Silverado against the rev limiter then clik off another gear manually
Old 04-18-2006, 09:36 PM
Thanks guys for the quick reply !
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
chevy block question joesnova2 Engine 15 05-01-2007 09:20 PM
56' Chevy Rear Bumper Question maxie56 Body - Exterior 2 05-25-2005 09:11 AM
Trans Question on my 2001 Chevy Silverado onebadmerc Transmission - Rearend 2 01-04-2004 03:04 PM
Mustang II Booster in a '49 Chevy Question hiimed Suspension - Brakes - Steering 4 03-11-2003 07:32 PM
