Chevy 5.3L Specs???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2009, 01:56 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
Buddy has a stock 2000 5.3L silverado truck that runs pretty good( cant outrun my 86 silverado though). I was just wondering what where the engine specs, tranny, gear ratio, cam, heads( think vortec) etc etc where these model years and are they superior to the 87-98 years. JUST CURIOUS
Old 04-21-2009, 09:34 PM
fast68's Avatar
likes chevy trucks & boobies
hi there
well youll have to get the RPO codes off the truck for the axle ratio as there were more than one
and more than one 5.3L engine possibly.
there will be an RPO code for that as well.
axle RPO codes are G codes
engine RPO codes were L codes
http://en.wikipedia.org/wiki/Chevrolet_Silverado is a good start
superior is just a relative term and is usually opinionated. anything is superior if you believe it is, in your own mind. all engines have their own problems, and also their own superiorities.
also remove the h from where as it makes your posts confusing to read.
good luck!
Old 04-21-2009, 10:42 PM
Engine specs on a 2000 LM7 (5.3) are I believe 285hp/325ft-lbs
3.779in bore x 3.622in stroke
4L60-E Transmission probably
gears can range from 3.42's to 4.11's
stock cam is about 190/191
The heads are almost identical to LS1 heads but with smaller 61cc combustion chambers.
I personally consider the 5.3 superior to the 350 Vortec except for the 1999 5.3's. The 350 has a lower torque peak, but the LM7 has a broader torque curve and 30 more hp. As for the 87-95 years the 5.3 and the 350 Vortec both blow them out of the water. That's just my opinion tho and I am sure many guys will side with the 350 Vortec. I have a 2003 Chevy pickup with a 5.3. Only mods are exhaust, cold air, and a custom computer tune, and it runs good for what it is.
One major note about the 4.8/5.3/6.0 is that these engines do not interchange any parts with the original Small block chevy, besides the cam bearings (and maybe the roller lifters?)
who knows about chevy blue engine paint? doechsle Engine 2 03-31-2006 08:28 PM
Bought my first BB chevy/ need help with specs!! Fattire_70 Engine 5 03-01-2006 11:45 PM
Please Help!!!! Need 57 Chevy Specs!!!! chevygirl57 Engine 2 03-01-2006 10:39 AM
79 350 chevy engine specs davekreis Engine 2 02-25-2006 09:54 PM
chevy 10 bolt rearends torgue specs fuman Transmission - Rearend 0 12-24-2002 11:26 AM
