Chevy 5.7 TPI - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-30-2005, 08:45 PM
New Member
Last journal entry: 1938 chevy just sold it
Chevy 5.7 TPI
i have a chevy 1991 5.7 tbi motor that i have and going to put a 1987 TPI setup on it They said that the year from 1986 to 1992 is the same . is it ??. I have a chance to buy a tpi intake fuel rails,runners and plennum set up for 9th injector everthing is polished. off a chevy 1985 5.7 will this set up work?
Old 07-30-2005, 09:11 PM
chrisflock's Avatar
Last journal entry: A quick trip
Only difference I've ever heard about in those TPI's was the 9th injector for cold starting, I know that on some vehicles that 9th injector was not there, and that instead all 8 injectors fired a 'prime' shot for cold starting, but I don't know when and what...I also recall reading about some minor difference between corvette and camaro TPI setups, perhaps something to do with fuel inlets being on different sides? I can't recall...
But, as long as you have the whole TPI setup, you should be set.
Chris
Old 07-30-2005, 09:19 PM
New Member
chevy tpi
i heard that the angle of the intake bolts was not the same. that what i heard
Old 07-31-2005, 01:53 AM
Siggy_Freud's Avatar
In 87' they changed the center intake bolt angle on the heads. 85-86 TPI's will work on older heads. 87-Later will have to be machined (fairly simple to have done) to work on the early style heads.
Bringing history and technology together.
Old 07-31-2005, 06:38 AM
jesse01's Avatar
mini me
this is very true
but i would go on e-bay and find a tpi intake manifold of a '85-'86 corvette this will bolt right on and will let a little more air through
Old 07-31-2005, 06:50 AM
edge's Avatar
Time is short, are you ready?
Originally Posted by jesse01
this is very true
A TPI intake from an 85'-86' Corvette has traditional 90* bolt angles. The 91' TBI engine he wants to put the TPI intake on has canted intake bolt angles for the four center holes (Can't remember the revised angle). See below:
Furthermore, why would he do that, everything is polished?
Question for Hotrod1935: Please clarify, is the TPI from 1987 or 1985? If 1987 (non-Corvette aluminum head), it will bolt on to the 91' heads without modification. If from pre-87' or an aluminum head Corvette TPI, you will have to have the four center bolt holes modified for the canted holes in the 91' heads.
TPI Swap in 94' Suburban
Best of luck, Ed www.edgesz28.com
Last edited by edge; 07-31-2005 at 07:02 AM. Reason: Need clarification on what the TPI is from
Old 07-31-2005, 06:53 AM
jesse01's Avatar
mini me
oh ya he must be going for looks forgot about the "polished" comment
i was thinking more hp like always. If i had it my way everyone w/a 5.7 tpi should get a super ram instead
J
Old 07-31-2005, 07:09 AM
jesse01's Avatar
mini me
your right my bad, i got confused for a sec i thaught he said he was putting it on a '85 350 and that the tpi came off of a 91
i had it backwards
J
Old 07-31-2005, 07:13 AM
jesse01's Avatar
mini me
i don't like the idea of putting a stock tpi on a 350 since the tpi was originally designed for a engine that was 45 cubic inches smaller
Old 07-31-2005, 08:34 AM
New Member
tpi
thanks guys. i have a tbi motor 5.7 1991 not corvette. I have a 87 camaro tpi unit. the one i can get is the 1985 tpi unit polished fuel rails,runners and plennum set up for 9th injector but the intake is not polished . can i take everthing off the intake and put it on my 91 tpi . or would it be easy to just polished my parts. (I can buy the 85 tpi for $100)
Old 07-31-2005, 09:10 AM
jesse01's Avatar
mini me
did you mean can you take everything off the '85 tpi and put it on the '87 intake manifold?
yes you can
Old 07-31-2005, 09:42 AM
New Member
tpi
Thanks jesse01. that what i wanted to know they both have the 9 injector then if i wanted a polished intake i can polished mine it a lot of work to polished the parts that why i want to buy it $100
OOo... I hate chevy people! 87442lover Hotrodders' Lounge 64 01-23-2006 08:10 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
Chevy sending unit in a Ford Tank AnD Engine 0 05-14-2003 04:34 PM
1997 5.7 Vortec Conversion 71ChevySWB Engine 2 01-14-2003 07:42 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
