Chevy 5.7 Vortec timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2007, 08:35 AM
Last journal entry: 1965/66 Impala body lines.
I'm in the proccess of switching out my Chevy 5.0 Vortec (old and tired) for a fresh Chevy 5.7 Vortec. I can't seem to find any timing information for these engines. I know that the spark is computer controlled, but there is still a distributor that needs to be attended to. How do you set initial timing so the computer can find the mark? Thanks
Old 01-12-2008, 07:42 PM
bring you motor to tdc pull the distibuter there is a white PAINT mark just below the base of the distrbuter cap and on the bottom of the shaft a pre drilled hole, line the two up drop in the distributer in tight, once in the roter cap/button should be pointing between a #6 and #8 which if you look carfuly on the base were the distributer cap sit and screws too there are the two numbers 6 and 8 if its not it is out a of its 0 degree just make sure to line up the paint mark with that hole and drop it in the hole is not straight through it is just a dimple but remember that your cap sould be put on with the coil side a pasanger side if not your 180 out turn it a round hope this helps
V Belt for 5.7 liter Vortec Block Sly's 53 Suburban Engine 13 06-21-2015 08:36 PM
Bb Chevy Ignition Timing leejoy Engine 13 03-01-2006 02:09 PM
96 chevy 305 vortec heads on 350 block badriand Engine 6 02-20-2006 07:45 AM
Chevy 5.7 TPI hotrod1935 Engine 11 07-31-2005 09:42 AM
87 Chevy Pickup Timing Problem gs70ss Electrical 2 10-19-2003 11:04 AM
