Chevy 502/502
how hot should a Chevy 502/502 run
502/502
I am helping my friend who is not real good on the computer. He has 69 El Camino with the 502/502. He is not able to get the temp below (I think) 230-240. What kind of cooling system would you think would work? Thanks for your reply.
T |
chevy 502 water pump (short water pump) running flex fan. running 2 elect. fans 14 in. ( should put out 2950 cfm each) alum radiator 2 core. stock shroud. running about 205 to 220 temp at about 93 outside.
Thanks so much!!!! |
You should only need 1 fan. Make sure you have one of the good flex fans. Not one of those cheapo ones from the local parts stores. They like to throw blades. |
Mine runs at 185-190 when moving and that's in 100* + heat. 195* in stop and go traffic in the middle of the day. At night it runs at 185 all the time (except when I run it up to 6 grand a couple times). I have the HO 502 in my Bird, it has less compression (8.75:1, not 10:1) and iron heads. It pulls that same amount of torque but about 50 less hp. It used to run at 210-215 before I realized that it had a standard rotation pump spinning in reverse.
The water pump that comes with the engine is a standard rotation pump. If you put a serpentine setup on, you're spinning the pump in reverse. Been there, done that. I have a 2 core aluminum radiator (31"x19", 1" passages). A 16" electric puller fan and modified stock fan shroud. 185* High flow thermostat. High volume water pump. I run about 40/60 coolant/water with some of the redline water wetter. The temps didn't change with the water wetter but I use it anyways. |
(yikes) however, it is worth it since that fan is excellent at cooling. You get what you pay for applies here.
| SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine | Oldsmolac911 | Hotrodders' Lounge | 50 | 01-12-2011 10:00 PM |
| 9" to chevy conversion | bigiron | Transmission - Rearend | 4 | 10-11-2005 10:32 PM |
| 36-39 Chevy Sedan frames | Rufus_2 | General Rodding Tech | 5 | 09-02-2004 12:52 PM |
| Can you use a 1933 or 1935 Chevy transmission in a 1934 Chevy? | mistermuscles | Transmission - Rearend | 0 | 07-18-2004 05:40 PM |
| New Member Introduction - 48 Chevy Rodder | 48 Chevy Rodder | Hotrodders' Lounge | 0 | 10-20-2001 03:04 AM |
