We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 11-06-2009, 09:28 AM
jwc jwc is offline
chevy 6.5 turbo diesel oil cooler lines
i have a 1997 Chevy 3500 dually with a 6.5 turbo diesel and i need to change the engine oil cooler lines because they are leaking. i have not owned a diesel until now so my knowledge is limited. can any one tell me the procedure for removing and replacing these lines? they appear to have a screw in adapter that the lines snap lock into at the engine block. i don't know if i should remove them at the adapter or try to unlock them at the snap lock. also is there enough room between the lines and the exhaust to get them off?
Old 11-06-2009, 10:25 AM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
They unlock. There is a wire retaining clip that goes around the circumference of the adapter. You remove this clip (don't lose them!!) and pull the line out. The put the clips back in, and you just push the new lines in to install. Make sure you hear the "click" when you install the new lines, otherwise they will fall out and bye-bye oil!
Old 11-06-2009, 10:59 AM
jwc jwc is offline
6.5 diesel oil lines
thank you for the imfo, do you know if i'll need to mve the exhaust manifold for clearance to remove the line?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "chevy 6.5 turbo diesel oil cooler lines"
Block Oil cooler - Can I plug them? unstable Engine 13 09-29-2007 12:38 PM
Trans. cooler lines Novaman78 Transmission - Rearend 12 10-08-2006 07:15 AM
89 chevy 1/2 ton 5-speed truck gear oil??? tiresmoke55 Transmission - Rearend 12 09-12-2006 10:46 PM
oil leak rb8179 Engine 11 06-03-2006 03:07 AM
Chevy oil pumps Knobie Engine 1 01-16-2003 03:52 PM
