Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated June 18th, 2009
#1
Crosley
520 edits
#2
Crashfarmer
401 edits
#3
Alittle1
295 edits
#4
Techinspector1
173 edits
#5
Powerrodsmike
157 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 09-22-2008, 06:49 AM
tdwuph tdwuph is offline
chevy 6 cylinder 700r4?
is it possible to convert the transmission in my 63 chevy belair 6 cylinder from a 2 speed to a 4 speed? any advice is appreciated todd in minnesota
Old 09-22-2008, 08:48 AM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Hi,
this is from Hotrodders knowledge base.
Rich
I forgot something, a 200r4 would be a better choice, it's the
same length as the two speed you have now & you'll have OD
http://www.hotrodders.com/articles/TH-700R4_basics.html
Old 09-22-2008, 02:40 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
like already said the short answer is yes
but there are length issues
3" length issue
700r4 is the longer tail length same as th350 with truck and wagon 9" tailshaft
and i assume the powerglide you have is shorter 6"tail tranny length
so a 2004r will be the direct bolt in way to go unless you have no driveshaft at all currently
GM 2wd all have generally two different lengths other than ther th400 which is all alone by itself different lengths than all other gm tranny models other than the small 3 speed manuals such as the SM318 in which are evne shorter than the 6" tail, and 200 series 3 speed auto trannies, and 2004r of course
good luck
Old 09-22-2008, 05:41 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstarLast wiki edit: Troubleshooting torque converters
Wiki Edits: 550
You will need to put a tape measure to this 2 speed trans in the 63 car... should be an aluminum power glide.
Early glides had different lengths than the common t-350 trans with 6 inch long tail housing.
The early glides also had a course spline yoke and output shaft. You would need a 27 spline yoke for the more modern trans.
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "chevy 6 cylinder 700r4?"
which small block chevy cylinder head? pds23 Engine 2 07-22-2008 06:19 AM
700r4 chevy, 200r4 BOP convertion Feyr Transmission - Rearend 4 06-27-2008 04:15 PM
50 Chevy truck master cylinder kit mr52pickup Suspension - Brakes - Steering 1 11-21-2006 11:01 PM
chevy cylinder heads Mike Cleary Engine 1 10-18-2006 01:46 PM
swapping a 700r4 with a turbo 350 on 4x4 chevy trucklover Transmission - Rearend 3 12-22-2002 05:39 PM
