Chevy 605 Power Steering Gear Box - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2007, 06:57 PM
What car and year did the 605 power steering gear box come on.THANKS
Old 06-14-2007, 05:03 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
GM Box Interchange - Provided by Jim 'Canuck' Campbell
A list of direct bolt-on boxes and some that need modifications.
(Note this list refers to Saginaw 605 Power boxes but would probably apply to manual as well.)
Interchange #706
Buick Special 64-70 Camaro 67-74 Chevelle 64-70
Chevy 65-70 Firebird 67-73 Grand Prix 69-70
Monte Carlo 70 Monza 75-79, 8cyl Monza 78-80,6cyl
Nova 68-70 Olds 64-70 F-85 64-70
Pontiac 64-70 Skyhawk 75-80 Starfire 75
Starfire 76-80, 6 cyl Starfire 77-79, 8cyl Sunbird 76-80
Tempest 64-70
Fast Ratio Box: 20/1 # 7806396 Cast No. 5679142
Monza/Vega Box: 16/1 # 7819935
On some 64-70 the drag link hole on the pitman arm may need to be enlarged.
The following boxes will fit but may need to have the pitman arm and/or the rag joint changed or and extra bolt hole boss taked off the steering box. Make sure you compare the input shaft length or the length from the bolt holes to the end of the input shaft to your power box.
Interchange #999
Apollo 73-75 Omega 73-79
Chevelle 71-77 Skylark 75-79
Monte Carlo 71 Regal 73-74
F-85 71-72 Nova 71-79
Lemans 72-77 Cutlass 76
Ventura 71-77 Phoenix 77-79
Century 73-74 Tempest 71
GMC Sprint 71-77
Cutlass 73
Interchange #989
AMC Ambassador 70-2
AMC 77-80
AMC Spirit 79-83
AMC Hornet 70-77
AMC Concord 78-83
AMC Matador 71-76
AMC Gremlin 70-78
Interchange #1034
Jeepster 72
Jeep 73-83
Jeep CJ & DJ 72
Jeep CJ 84-86
List was derived from Hollander Interchange Manual
Fast ratio Power Steering- Saginaw 605
Use box from 1977-81 Camaro/Firebird with disc brakes (or any 800 series box used in Novas, full size GM, etc), gives approx 3 turns lock to lock, versus original power steering 4.5 turns.
All later model boxes require the 1964 - 72 Chevelle pitman PS arm (required change) when used on earlier Chevelles.
Steering shaft comes in two diameters, get the appropriate flex coupling lower half in the same style as original to match the boxes shaft.
1982 or 86 to 92 Comaro Z-28/firebird Trans-AM are 2 turns (12:1) lock to lock, Use original end cap to get the right stops on 2 turn boxes to decrease turning radius.
Later model boxes (1980 and up) use "O" rings instead of flared input and output lines.
Later model internals can be swapped into early boxes to eliminate problems with line fittings and stops or pump can be modified by changing outlet valve (this requires verification) or swapped to accept "O" ring hosed.
Old 10-17-2007, 09:47 AM
Saginaw power steering box
F&J
I hope you can maybe help me with my problem. I have a 1957 Chevy pickup that I am converting to 4X4 using parts from a 1979 Chevy 1/2 ton pickup. I have a Saginaw power steering box that has the pressure opening threads stripped. Is this an 11/16 opening with 18 threads? I need to get a tap and rethread the opening. I need to know what tap I need- can you or anybody out there help me out. Thanks Jim C
Old 10-17-2007, 12:47 PM
F&J F&J is offline
I don't have a hose handy that I can measure. Can you measure the hose end you have? Or use a "thread pitch gauge" that usually is in a tap & die set? A 11/16 should be an 18 where a 3/4 would be a 16.
You may not have enough room to use a tap unless you can find a "bottoming" tap that is not tapered much.
There was a switch from flared hose fittings to O-ring fittings sometime around your year. If it is a flare fitting, there should be a brass tapered seat at the bottom of the pressure hose hole. I have read that that can be pulled out, maybe by threading it and using a bolt. If you get it out, there would be more room for a tap.
I tried google for the fitting size but could not find it, sorry.
Old 10-18-2007, 10:13 AM
I got the brass seat out and am trying to find an 11/16-18 tap to use. It looks like I might get this thing fixed! I appreciate the tips...I would not have enough room without removing that seat. thanks again
jim C
power steering box conversion - w/o fluid? stratt134 Suspension - Brakes - Steering 3 07-27-2006 06:16 PM
capping off a power steering box? tombo615 Suspension - Brakes - Steering 1 06-24-2006 07:35 PM
Mustang Power Steering Box 55 GMC100Tuckin Suspension - Brakes - Steering 2 08-02-2005 05:28 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 10:50 AM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 11:15 AM
