chevy 68 327 initial timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2007, 02:47 PM
Does anyone know the timing for a 68 327?
Old 03-28-2007, 03:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If it's a standard (under 300 hp) 327, the timing is:
  • TDC for manual trans.
  • 4 BTDC For Automatic.
  • Point gap is 19 thousands.
  • Dwell angle is 28 to 32.
  • Idle 700 RPM's
Set your points, Check your timing, then set your Dwell angle at 2000 RPM's, THEN recheck the timing, Dwell will effect a change in timing.
Doc
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
what is the fastest (factory) car you have ever driven? badknuckles Hotrodders' Lounge 320 12-09-2011 01:32 AM
Bug with 327 Chevy wahoo Hotrodders' Lounge 11 02-20-2011 03:07 PM
Small block chevy timing Anton Engine 1 06-16-2005 10:27 PM
high initial timing (part 2) stinky jinx Engine 3 08-15-2004 04:54 PM
