chevy 700r4 transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2011, 10:38 AM
havingproblems with slip in all gears is there a simple test that can be run to help diagnose problems
Old 02-19-2011, 01:41 AM
SSedan64's Avatar
TV cable adjusted properly? A pressure test will give more Info. Test Port above manual Shift Shaft on driver side of Trans.
More Info.
Trans mileage? year? Carb/EFI? Any work been done?
700R4 Transmission my37rod Transmission - Rearend 3 03-11-2009 07:15 PM
v6 700r4 transmission leldai73 Transmission - Rearend 2 05-06-2008 11:07 AM
The Chevy TH-700R4 Transmission. M&M CUSTOM Transmission - Rearend 6 08-24-2004 03:19 PM
700R4 Transmission Jrec Transmission - Rearend 2 12-30-2002 06:08 PM
700R4 transmission beetle9 Transmission - Rearend 9 09-17-2002 03:02 AM
