Chevy 8.2 Pinion Nut - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2006, 03:32 PM
MI2600's Avatar
Member# 3287
I picked up a 10-bolt 3.08 rear end for my '72 El Camino, to replace the 3.55 that's killing me gas-wise in town.
Anyway, the yoke was off. When I went to install the pinion nut I noticed the threads on the pinion were slightly damaged and I can't get the nut on. It looks to be 7/8" by 16 pitch.
Can anyone confirm that? I may need to use a die on the threads if I can't clean them up.
Old 04-19-2006, 11:12 AM
MI2600's Avatar
Member# 3287
Confirmed. 7/8" by 16...a special size compliments of GM.
Old 04-19-2006, 01:03 PM
48ChryslerRodder's Avatar
Stuck in the past.
If you can't find a die that size, try using a thread file. Any good tool store should have a set. They come in standard, metric, hydraulic, and pipe threads.Used carefully you should be able to clean the threads. They are great for those manufacturer proprietary items.
Old 04-20-2006, 06:17 AM
MI2600's Avatar
Member# 3287
Yes, I used a thread file yesterday and finally got it on.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
9" to chevy conversion bigiron Transmission - Rearend 4 10-11-2005 10:32 PM
10 bolt rear end question 8.2 or 8.5 ?? nheron Introduce Yourself 1 09-14-2004 09:26 PM
Pinion Angle Mystery Dep ME Transmission - Rearend 17 08-18-2004 12:02 PM
57 chevy rack and pinion romine Suspension - Brakes - Steering 5 07-06-2004 07:43 PM
