chevy 8.5 wheel studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2010, 08:07 PM
I need to change the (lug) studs on my g-bodied 8 1/2 inch 10 bolt rear end. The Weld wheels that I am useing have a rather thick hub ,and had to put them on with a long lug. For saftey sake can anyone tell me if the lugs are pressed in or screwed in? I plan to install some much longer studs and would like to be prepared.
Old 08-27-2010, 08:12 PM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
I have never seen a screwed in wheel stud . You may or may not be able to get longer studs with the same diameter splined shank . I had to put longer studs in every hub on my T-bucket and had to buy a drill bit to drill out the holes after I knocked out the old studs . Make sure you get the bit about .020 smaller than the O.D. of the splines . Buy a handful of regular lug nuts and some washers to pull the new studs in . (put the flat side of the nut toward the hub) Use plenty of never seize to keep from galling the threads as you pull the studs in . Worked for me .l
Old 08-27-2010, 09:06 PM
ericnova72's Avatar
More for Less Racer
Factory axles use pressed-in splined lug studs, only aftermarket axles are threaded for screw-ins.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Wheel Studs 58 Apache apache235 Transmission - Rearend 4 04-19-2009 10:35 AM
Question About Wheel Studs leejoy Transmission - Rearend 10 06-11-2008 11:11 PM
8.5 10 Bolt Chevy Info Needed jsteve068 Transmission - Rearend 6 09-26-2005 04:09 PM
Wheel Studs on 1940 Desoto mile-hightoyz Suspension - Brakes - Steering 3 09-12-2004 08:34 PM
