Chevy AD truck 6 lug to 5 lug chevy car pattern - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2011, 06:59 PM
I searched w/ no luck, i know I've seen it here.
Can I take the front drums from a '51 chevy car and use them on an AD truck?
Old 08-29-2011, 08:39 PM
41'srfun's Avatar
Last journal entry: 41' finally has paint on it
Yes, it's an easy way to convert to a 5 lug pattern on the front
Old 08-30-2011, 02:16 PM
I believe it depends on the year truck. I THINK (not sure) that up to 50 you need to change the backing plates and spindles as well. After that the backing plates and spindles are the same as the car. I seem to remember something like that.
Old 08-30-2011, 02:53 PM
I just got the drums, brakes,and backing plate, but not the spindles. I'm going to go check now, to see if they fit.
Old 08-30-2011, 04:42 PM
Checked the fit:
'51 Chevy car to '50 Chevy truck.
Drum fit spindle.
Inter truck bearing dust cover is a little larger in dia.
chevy camaro vs chevy pickup bolt pattern old fords Transmission - Rearend 2 09-19-2008 06:07 PM
Pattern for 58 chevy fllet side truck Lee Hester Body - Exterior 1 10-27-2006 02:27 PM
Chevy truck 5 inch wheel pattern to 4 .75 musky2 Suspension - Brakes - Steering 1 05-12-2006 07:23 AM
Bolt pattern chevy 350 strokercuda Engine 2 12-02-2004 08:17 PM
82 Chevy Truck change to small pattern musky2 Suspension - Brakes - Steering 11 01-09-2004 08:56 PM
