Chet |
Start the vehicle, turn all electrical items on (lights, fan etc.) alt. should carry the load. If not, time to pull it off and check it on the tester.
Check out this website for some electrical explanations on alternators and vehicle electrical systems.
I had similar readings on my '75 350, and when I turned on the headlights and heater blower, it dropped to about 11 volts with the engine running at 3k RPM. I couldn't drive at night for any length of time because the alternator could not keep up.
The GM 10si alternator should have been standard in 1980, and they came in versions with up to 63 amps. If you had factory AC, it was probably a 63 amp alternator. The 10si was later replaced with the 12si version, which had output of up to about 94 amps. The 12si can be a direct replacement for the 10si, as long as you get the V belt pulley (not the serpentine belt version), and upgrade the charge wire from 10 gauge to 8 gauge (including a 12 gauge fusible link). I'm using a 1985 vintage 12si on my '75 engine, and it charges very well. You need to find a 12si with the same "clocking" as your current alternator. Clocking refers to the position of the power plugs relative to the mounting brackets. If clocking is wrong, the wires might not reach, or the plug might end up down next to the valve cover where you don't have clearance. I used the data from the web link at Mad Electrical, but some of the parts numbers didn't quite match those at the parts store. I had to have the auto parts place pull a couple of alternators before I found one with the V-belt pulley and the right clocking. Bruce |
75gmck25,
Thanks for the info. After doing *LOTS* of research on alternators with the provided links I found out I did have a 12SI 94 amp. Still suspicious of it I swapped it out with a 10SI 63 amp and low and behold.... 14.2 volts varying with my idle. I just happen to have this other alt. laying around, lucky me. So, off to Auto Zone with the 12SI and the guy tells me its fine?????? Then driving home I notice that even the 10SI starts dropping to mid 13's. Could I have two bad alternators? Could it be the heat? Who knows, I'm going to keep the 10si in until something catastrophic happens and go from there. Do you know of a place that sells rebuild kits for these things? Darrin |
Rebuild kits should be available from most full service auto parts stores. Summit Racing also sells the Powermaster rebuild kit online.
My 12si charges at about 14 volts when I first start the truck, and then drops to mid 13's after the battery is fully charged. Even with all the lights on and the blower motor on high, it never drops below about 13.5 when the engine is running, even at idle. Bruce |
Chet |
| What's the proper way to wire an alternator? | 70bird | Electrical | 18 | 08-14-2010 12:24 PM |
| Generator to Chevy Alternator Conversion | mred | Electrical | 3 | 07-31-2006 06:01 PM |
| Mazda mx-6 alternator not charging | 1quiknova | Electrical | 6 | 12-06-2005 09:49 PM |
| Alternator or other electrical problem ? | Claude | Electrical | 2 | 08-26-2005 07:10 PM |
| 57 Chevy Generator to Alternator | dirtroaddrifter | Electrical | 1 | 12-06-2002 08:08 PM |
