-   -   **chevy Aluminum 113 Heads** (http://www.hotrodders.com/forum/chevy-aluminum-113-heads-168440.html)
nawlins-tim 11-14-2009 07:22 AM
I HAVE A 1980 CHEVY 350 BLOCK .30 OVER AND RECENTLY PUT A SET OF THE ALUMINUM 113 HEADS ON IT. ALL SEEMS OK BUT I HAVE TO GET BACK UNDER THE VALVE COVERS TO CHECK OUT A SLIGHT ROCKER TAP.
CAN ANYONE TELL ME THE YEAR THOSE HEADS CAME ON THE CORVETTE(AND CAMARO TOO I THINK) . You see all I have around here is auto parts places like Auto Zone, Advance , etc. When I go asking for any product they start out with "year and model" please . I can't just go in asking for center bolt valve cover gaskets. SO CAN ANYBODY TELL ME THE YEAR MAKE AND MODEL THE ALUMINUM 113 HEADS CAME ON PLEASE. THANKS. TIM
curtis73 11-14-2009 09:28 AM
If its just the gaskets you need, any chevy V8 from 86-97 will do the trick; TPI, TBI, LT1. Just ask for something like 1990 chevy truck with a 5.7L and it will get you what you need.
nawlins-tim 11-14-2009 09:51 AM
thanks didn't know so many used center bolt valve cover bolts.
Jim Rockford 11-14-2009 05:44 PM
yea , everything after 86 had centerbolt valve covers.
302 Z28 11-14-2009 07:17 PM
Moderators note: Please remove the asterisks in your thread title, they will not keep your thread on top, but they will render your post search less if anyone tires to use the search function.
Vince
