454
Stick with the 454. Both are BB. Almost every part, excluding the crank, are interchangeable. So there is no cost savings in buying parts for the 402, which is just a .030 over 396. There is no replacement for displacement.
Maybe we missunderstood. I got both engines and I want to build up the 402 for a rat car / dirt car or something like that. My Maro gets the 454. The 402 is for fun and learning effect only.
So when the blocks are the same, what would be a good upgrade for this engine? Is there a payable 502 stroker kit or something like that? |
The 402 has a 3.76 stroke an a smaller bore than the 454.
The 454 is a 4.00 stroke with a 4.250 bore. They are made on the same principle but with different parts. The 3.76 stroke crank an a 454 block (4.250) will give you a 427. There is not much you can change without going to a different block. Unless you just wanted to build the 402. |
My "Maro"?!?!?!??!?!?!?!?!?!?!?!? Please stop that. It is an insult to all of us Camaro owners. It is as ridiculous as one of the magazines that insists that calling a Chevelle a "Velle" is cool. Cut it out. Please.
Probe makes a 30cc dome piston. With some 112cc open chamber heads (like maybe some 049's decked down to 112), zero deck and 4.125" bore, you would be right at 10.0:1. Use a cam something like this solid flat tappet cam with EDM machined lifters to spit oil directly onto the lobes from the bottom of the lifter housing.
http://www.summitracing.com/parts/ISK-396266/ http://www.probeindustries.com/Chevy...ons_s/1026.htm |
| 307 Chevy build-up | JAKE 68 GMC | Engine | 18 | 01-26-2012 11:37 AM |
| Chevy 355 Build | 85c10SS | Engine | 7 | 02-17-2010 06:10 AM |
| 307 Chevy build-up | JAKE 68 GMC | Engine | 2 | 09-24-2006 07:19 AM |
| trying to build a 55 chevy | tiresmoke55 | Introduce Yourself | 3 | 01-13-2006 07:11 PM |
| Chevy 350 build | Jditlfm | General Rodding Tech | 9 | 09-16-2004 12:44 PM |
