We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 05-14-2005, 12:00 PM
crashtech's Avatar
crashtech crashtech is offline
Technician
crashtech's barnstar
Wiki editor
Last wiki edit: How to start hotrodding with little knowledge or money
Wiki Edits: 14
Chevy BB Head Milling
I have an 84 Chevy P/U with a 454. The cam went flat, and I'm in process of disassembling the engine enough to change the cam. While I'm at it, I would like to remove the heads and have them milled, as well as use steel shim head gasket. According to some math I did, if I can get about .050 out of this arrangement, the engine will gain about .7 of a point to 8.7 to 1 compression ratio, which would be acceptable for this truck. Raising the compression a bit will also allow me to run a slightly larger cam, which as a gear head I MUST do . I'm wondering what the safe maximum is for head milling on this era of big block head, and if I could go even more than the .020 I'm guessing will be necessary. (The guess will become more refined when I can measure the old and new head gaskets)
Old 05-14-2005, 12:05 PM
machine shop tom machine shop tom is offline
.020" to .030" should be no problem. Any more than that and you may have manifold issues.
tom
Old 05-14-2005, 12:16 PM
crashtech's Avatar
Technician
Wiki editor
Wiki Edits: 14
OK, I just spoke to my brother-in-law, and he has FREE cam for me, but it's even bigger than what I had in mind, 222/234deg@.050. I think I will need even more compression for this cam, or maybe I ought to pass up the freebie?
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Chevy BB Head Milling"
chevy head questions 455c-10 Engine 1 05-04-2005 09:15 AM
241 bb chevy heads "need info please" 406 ss monte Engine 1 05-27-2004 07:39 PM
(winters) tri power intake bb chevy prostreet silverado Engine 3 01-03-2004 06:18 AM
BB chevy pistons Gassman Engine 2 01-19-2003 05:22 PM
Milling Chevy Heads Larry Wilcox Engine 4 01-09-2003 07:22 PM
